Guest Raisin Posted May 25, 2007 Greetings! I have few questions: I am thinking about turbocharging my engine (low pressure boost, say ~0,4bar) and for the time being I'd like to keep it as low-budget as possible. Ok here go the questions 1) Is there any mechanical difference between DKZ and DDZ (apart from injection system) How about camshafts? 2) At what revs does the Solex 1B ECU cut off fuel\ignition. I have revved up to 6800RPM and experienced no cut-off. I don't want to wreck my engine if the limiter doesn't work 3) Will I need to replace pistons, rods to supercharge the engine and keep the durability 4) Literally - will the engine survive ~160HP with no oil spraying the pistons? 5) Any practical hints, ideas, links or places where the necessary equipment can be obtained? Regards! Share this post Link to post Share on other sites
petert 616 Posted May 25, 2007 What's a DDZ? I've never heard of that spec. Are you sure it isn't a DFZ? Share this post Link to post Share on other sites
Gentrix 2 1 Cars Posted May 25, 2007 (edited) from his sign Citroën BX19 TZi (XU9JMZ [DDZ]) Maybe a XU on Monopointinjection Edited May 25, 2007 by Gentrix Share this post Link to post Share on other sites
Guest Raisin Posted May 25, 2007 from his signCitroën BX19 TZi (XU9JMZ [DDZ]) Maybe a XU on Monopointinjection Yes indeed...a monopoint (Solex Fenix 1B) As far as I can figure it out it's DKZ head and bottom, the only doubts I have are about camshaft. CR is 9,2:1 HP=110 at 6200 RPM, max torque is 155Nm at 3000 RPM I can put some photos of the underbonnet wiev if ye like I am surprised that none of the DDZ or RFZ were present in P205 Share this post Link to post Share on other sites
Guest Raisin Posted May 25, 2007 So, it seems that nobody can help me? It looks like British market has not seen monopoint versions of XU5\XU9. I have checked my Haynes British edition and it doesn't say anything about monopoints. I guess these were produced for the German market. Mine is the 1.9 SPI with catalyst converter... Anyway, what are the maximum revs in XU9JAZ (DKZ) engine? Share this post Link to post Share on other sites
