DamirGTI
Options For Ignition
DamirGTI
Hi !
I have 1.9 D6B engine with 11.1 CR (flat top pistons) potred head , 3 angle seats ... and have problems with ignition - engine now detonate on factory ignition timing .
I've set timing now almost to the end beyond 5 degree and it is ok. detonate only in 4-th or 5-th on full load started from 2000rpm in these two gears on 98 octane gas , but idle speed is now bad which I can't adjust revs jumping all over from 700rmp to 1000-1200rmp and most importent engine has no power :(
What would be the cheapest solution to make mappable ignition ?
I've try sending e-mails to :http://www.h-h-ignitionsolutions.co.uk (for distributor springs changing) , but with no luck can't get in touch with them ..
Damir
j_turnell
Probably best off getting an after market igntion system such as omex. This was covered recently a search should bring up some results.
Rippthrough
Megajolt!
Mapped ignition or a recurved dizzy are the two alternatives. You still need 31-32 degs. of total advance for maximum power, but as you've discovered, it will now ping badly in the 2000-3000 region. I'd buy a full fuel/ignition ECU. The cost is not much more and still uses all the same sensors.
DamirGTI
Ok. Thanks :lol:
How about this Megajolt ? how hard is this for building , installing and setting up by myself ?
Damir
PumaRacing
  DamirGTI said:
Hi !
Are you guessing or have you measured things properly? Without the 14.5cc dish in the standard 1.9 pistons the CR would be 12.3.
Edited by PumaRacing
DamirGTI
Sorry just guessing ;)
The pistons are from 1.9 DFZ engine , but same sa the ones in 1.6 engines althou i didn't mesure precise CR yet . I don't have compression tester :D
Damir
Rippthrough
Damir
Even if you did it wouldn't really help you with the exact compression ;)
DamirGTI
Yes , me thinks that almost all compression testers gives different readings when compared to each other .. :D
benlilly
Hi Damir,
You need to calculate the compression ratio of your engine.
Have a look here for a clear and detailed explanation
Pumaracing
A compression tester will only really measure how well the rings seal and if there are any valve clearance problems.
