sonofsam
Another Reason For Instrument Illuminations Not To Work
sonofsam
Hello my friends.,
For the life of me I cannot get the instrument bulbs to light up!
Sidelights are working, fuse13 is good, all the earths are fine.
Dimmer switch is functioning as are the heater control lights
and the warning lights.
Only thing I can think of is the stalk, is this a possibility?
Help..
Ta,
Sam.
steve@cornwall
  sonofsam said:
Hello my friends.,
Help..
Ta,
Sam.
I'd suspect the circuits on the back of the cluster, maybe where the plugs push on. Do you have a spare set you could try?
Edited by steve@cornwall
sonofsam
Im using the circuit backing I got from a fellow member recently along with a blank dial holder
with just the bulbs inserted , no spare Im afraid :(
Theo205
Recently i Had a similar problem. whenever i went into a bump the instrument lights went off so did my rear light units.
I turned off the lights and then back on and everything worked fine.
Turns out it was the stalk and replaced it
As remote as it sounds if everything else failed try a different stalk
Theo
inferno
surely the stalk controls the other lights too.... strange but hey its french :(
sonofsam
B (green):
1. ?
2. ?
3. Instrument lights + (from dimmer) [25]
4. Instrument lights ground [M25]
5. Manual choke open warning light [75]
6. +12V [33]
7. Coolant level warning light [47B]
8. See A5
9. Direction indicator light, right [38A] (taken from the article on the main site)
Have noticed by way of the multimeter that No 2. goes to quite a few pins on the stalk plug.
Gave everything a good wiggle also with no joy.
Will try another stalk, just to rule it out. Hopefully it's that, if it isnt then im well stumped!
Cheers all :(
zowow
i had the same problem on my GTI. the dimmer switch was the problem on the lower dash, clean up the contacts on that and try!!
Jrod
Hey Sam,
If you wan to test another dash I've got one you can use, also got a stalk and the little dimming switch thing.
sonofsam
A quick scoot over to J's diagnosed the problem as the clocks I was using, do you know what
it was what mate, those three liitle bolts holding the circuits to the case itself :D:(:)
Happier than the proverbial pig..,
Thanks again dudes :D
Jrod
Obviously it was those that connected it to the other circuit.
Glad its fixed. :(
