Super Josh
Mi16, Which Lower Engine Mount?
Super Josh
I've been running a solid lower mount on my Mi, but I'm getting fed up with the vibration at idle ( old age kicking in, don't you know :lol: )
I am running a maniflow style exhaust manifold and wondered what mounts/experiences others have had?
Can I get away with a standard mount? Or a standard mount turned through 90 degrees, to stiffen it up a bit? Any other suggestions?
Josh
Mikey G
Solid i assume you mean the hard rubber mount and not an alloy block instead? If it is the rubber one drill a few holes in it to soften it up :lol:
pug_life
i'm trying my group N mounts on my mi16 this week...
They weren't that shakey on the 8v so i don't see too much difference..
old age josh, get a 405 mi16 instead :lol:
Alastairh
I understand what your saying as your becoming an old git :)
Wouldn't a 406 Dt one or similar be a good bet?
Quick search should find an answer for the one to go for :lol:
tom_m
xantia turbo FTW :lol:
Super Josh
According to Uncle Miles, Pug told him that the turbo one is no different to any other mount. Which is what you would expect from a big comfy cruiser, unless it's because of the Torque :). Tom, does your XM mount look any different to a standard one?
Josh
Edited by Super Josh
James_m
Ive got the xantia turbo one and it is certainly different to the old 205 one. My car is work in progress at the moment, so i cant really comment how well it controls engine movement.
Mikey G
My Xantia turbo has quite a bit of engine rock, similair to a standard GTi by the looks. but it has upper rubber donut mounts aswell as the lower unit to steady it a bit more i assume.
Peugeot have pretty much no idea about Peugeot parts so its pushing it expecting them to know about Citroen parts as well :lol::)
All Activas I've driven/owned have had knackered engine mounts so its worth replacing yours if you have a lot of engine movement.
16v205
I had a xantia turbo mount that was different to the normal xu jobbie, but after spending a few hours annoying the local citroen dealers we couldnt find a similar replacement.
Rich
Mikey G
I'd be surprised at 55k that my mounts are knackered, when i say it rocks i'm comparing it to a solidly mounted engine, it doesnt seem as soft as most but still moves around a bit. My Mi16 had knackered mounts, now that moved around a lot :lol:
I have no intention of chaging much on this engine untill it finds its way out of the car :)
my last activa had very knackered mounts when I got it on 61k with FSH (I bought it off a friend who got it when it was on 44k and it was fine then).
