Guest Scrapy Posted April 8, 2007 Anyone know how to go about fixing the remote central locking on a 1992 1.6. I changed the batteries and the light comes on in the remote but the car wont open with it? Share this post Link to post Share on other sites
pete1986 2 Posted April 8, 2007 I had the same problem with mine. Try taking the cover off the dome next to reading light and clean inside Share this post Link to post Share on other sites
Guest Scrapy Posted April 12, 2007 Hate to ask such a cak question but cant seem to work out how to get the dome out? Tried to take the whole casing down but cudnt do that either. Pulled out all the lites and only found 1 screw. I gave it a bit of a pull but scared tho break it. Non sunroof. Thanks Share this post Link to post Share on other sites
Guest Scrapy Posted April 12, 2007 Hate to ask such a cak question but cant seem to work out how to get the dome out? Tried to take the whole casing down but cudnt do that either. Pulled out all the lites and only found 1 screw. I gave it a bit of a pull but scared tho break it. Non sunroof. Thanks Ignore that msg. got it off and cleaned it but no good. Any other suggestions would be greatly appreciated Share this post Link to post Share on other sites
Phil H 16 Posted April 12, 2007 connections on the blue plug to the roof console have corroded? Remove connector and clean them up. Share this post Link to post Share on other sites
mossy 0 Posted April 13, 2007 Sorry to Hijack I would like to return my motor back to standard and want use the original remote central locking. I don't have the blipper but the roof mounted electrics are still there. Can you get a new blipper programmed to work the central locking? and where from?? I have a cobra fitted which does it at the mo but the alarm plays up so I'm going to rip it out. (I have a cat 1 seperate immobiliser fitted) Cheers Al Share this post Link to post Share on other sites
Phil H 16 Posted April 13, 2007 you can get the original receiver working, so long as it has the 5 digit code on it still, be like 45678 AD for example...then quote code to dealer who will get you a new remote, or like mine it has it in the key on a button. Costs about £55 for a new remote though. Share this post Link to post Share on other sites
mossy 0 Posted April 13, 2007 So will the code be marked on the electronics in the roof consoul? Cheers Al Share this post Link to post Share on other sites
Guest harry snotter Posted April 13, 2007 think mines is the same Share this post Link to post Share on other sites
Phil H 16 Posted April 14, 2007 So will the code be marked on the electronics in the roof consoul?Cheers Al on a small label on the outer casing. Share this post Link to post Share on other sites
mossy 0 Posted April 19, 2007 Cheers Philip I'll look into it. Al. Share this post Link to post Share on other sites
