Guest Foby
Problem Whit Engine
Guest Foby
I have problem with my 205 1,9 GTI , 1990 Y.
The car is normaly functioning , but sometimes it shakes and light bulb of "Engine check" is lighting all the time.
I tried remove + pole from battery for 10 mins. to reset computer and bulb was not lighting any more, but when i tried driving the car, it shakes , like he lost petrol on moment and bulb "Check Engine" was again lighting
What is wrong with car ? Maybe "Lambda sond" ? or somethin else ?
DamirGTI
Hi !
Which bulb is that ? you mean the red one or yellow ..
Check fuel pump relay ...
Richie-Van-GTi
how do you mean shakes? could it be dropping to 3 pots?
Guest Foby
The red one..
Guest Foby
He lost power at moment... something when dont have more fuel or lost a electrical power...
j_turnell
Check your Alternator is charging with a multimeter.
Andrwn8304
Check the connections on the fuel pump as the connections are outside and vunerable to the damp weather.
