andyjb
S16 Map Sensor
andyjb
Can anyone suggest somewhere i can buy a map sensor for my S16 without going to the main dealer? cheers
andyjb
Oh and i need a lambda sensor for the exhaust, is it only one a 306 S16 has?...... The parts CD shows two see.
sonofsam
The MAP sensor is inside the ECU, so maybe hunt breakers and online scrap merchants for an ECU
that you can take the MAP sensor from, or maybe try a Bosch dealer?
My 2.0L Turbo runs the same management as the S16 and only uses one lambda sensor,
you can buy universal three and four wire sensor's from a number of places.
Hope that helps
Sam.
andyjb
Hope that helps
Sam.
Would it just be easier to get a second hand unlocked ecu from a breaker?
sonofsam
I think you would have to be very lucky to find one, not saying you wont, but..
Google search online breakers and get some quotes generated.
andyjb
got one for 40 quid (unlocked non-keypad type)
