Bam 0 Posted March 16, 2007 (edited) hi folks, i asking myself: wich differences are between xu10j4 (97,8kw) vs xu10j4r(s) (110kw//120kw) EDIT: have found some infos (at the search) so...inletmanifold,cams and ecu are the pysical difference (?!) ecu: remapping would be work.... ...i'm looking for the missing hores... has anybody tried to fitt the gti-6 manifold to that 97kw engine? (wich power it would be produces without the +1mm lift s16 cam?) cheers mik Edited March 16, 2007 by Bam Share this post Link to post Share on other sites
Normski 1 Posted March 16, 2007 The cylinder head is completely different on these two motors. That's where the extra power comes from. Share this post Link to post Share on other sites
petert 558 Posted March 17, 2007 i asking myself:wich differences are between xu10j4 (97,8kw) vs xu10j4r(s) (110kw//120kw) There's misinformation for a start. You're mixing up three different versions: XU10J4 - 116kW, as fitted to series 2 Mi16 and S16 XU10J4R - 98KW, as fitted to 306 and early 406 models XU10J4RS - 125kW as fitted to GTi6 The heads on the later two are completely different to the first. The XU10J4 head is almost identical to a 1.9L Mi16. Cam timing is a major difference between the R and RS but there's others. eg exhaust, inlet, cyl. head etc. Share this post Link to post Share on other sites
Bam 0 Posted March 18, 2007 @peter u r right... pug is clever...they get a lot of "tiny" differences (began at the head, end at the block) to get +30bhp (healty) ...and i'm sorry...i have typed wrong (enginecodes) i'm not sure yet...to stress myself with this conversion (for "only" +30bhp) cheers mik Share this post Link to post Share on other sites
willxs 0 Posted March 19, 2007 Does the GTi-6 head fit onto the S16 block? Share this post Link to post Share on other sites
Bam 0 Posted March 20, 2007 here are some infos: xu10rs 120kw (gti-6/s16) inletmanifold: TB diameter: 63mm / 70mm xu10j4r 97,8 kw (406 2.0 16v) inletmanifold: TB diameter: 48mm / 54mm xu10rs 120kw (gti-6/s16) exhaustmanifold: xu10j4r 97,8kw (406 2.0 16v) exhaustmanifold: the 306 xu10j4r inlet manifold looks much different to both. valves xu10j4rs inlet: 34,10mm (!) exhaust: 30,xxmm (!) xu10j4r inlet: 34.60mm exhaust: 29,60mm valvestems on both engine: 6mm camtiming (info from search) RFV: 196°@1mm / 7.90mm Lift RFS: 215°@1mm / 10.00mm Lift inlet/exhaust duct-cross section ??? s16 block has a pistionbottomcooling. ECU gti-6//s16: magnetti marelli 406 2.0 16v: bosch any correctionsuggestion? cheers mik Share this post Link to post Share on other sites
B1ack_Mi16 67 Posted March 20, 2007 XU10J4 = S16 XU10J4RS = GTi6 These are not the same, they have different heads, exhaust manifolds and inlets. Also the XU10J4R head has exactly the same valve sizes as the S16/Mi16 with 7mm valve stems, while GTi6 is the one with 6mm valve stems and smaller inlets, bigger exhausts. Share this post Link to post Share on other sites
Bam 0 Posted March 20, 2007 XU10J4 = S16XU10J4RS = GTi6 i'm lil' bit confused... here in germany, is the "s16"...the same, that you are calling here "gti-6". peugeot 306 s16 (120kw)->xu10j4rs. >These are not the same, they have different heads, exhaust manifolds and inlets. pics above...i'm not sure...someone has tried to fit "gti-6" (xu10j4rs) inletmanifold to fit on his mi16.have seen some pic's. > while GTi6 is the one with 6mm valve stems and smaller inlets, bigger exhausts. so you agree? (list above, with valvesizes) stems: ok,thanks for correction ...but whats about willxs question? to swap xu10j4rs 120kw head (incl manifolds,cam) to 98kw xu10j4r ?! bore is the same (86x86) Share this post Link to post Share on other sites
B1ack_Mi16 67 Posted March 20, 2007 Lets call the XU10J4 for 405 Mi16 2.0 instead and drop the S16 thingy The XU10J4 has 155bhp and a black plastic inlet manifold and cast iron exhaust manifold. A XU10J4RS head would fit fine on a XU10J4R, I think the J4R will have 10.4:1 apart to the J4RS which has 10.8:1 compression. And also I'm not sure how big the valve-pockets are in the J4R compared to J4RS. But should fit just fine. Share this post Link to post Share on other sites
Bam 0 Posted March 21, 2007 hmmmm.... next question would be: i'm pretty sure, that a xu9j4 inletmanifold would fit the head from gti-6. does anybody tried? (cause of 2x38mm TB's or VAG tb with 83mm???) mik Share this post Link to post Share on other sites
Hilgie 16 2 Cars Posted March 22, 2007 yes that fits....I did it the other way around, GTi6 manifold on S16(Mi16)head: Share this post Link to post Share on other sites
Bam 0 Posted March 22, 2007 thx hilgie for the pix whats about the oilspraybars from the bottom end from gti-6? i also sure, that pug didnt make diff blocks, i think it should be possible to plug and play that parts but....oilpumppressure difference? .oO(what would happen with xu9j4 inlet and vag tb on xu10j4r,cams like this one: 268° 114° 10,5mm 1,1mm 20°-68° ) wich power should be possible?! mik Share this post Link to post Share on other sites
