Guest latestarter2
Plugin Performance Chips
Guest latestarter2
Ive noticed lots of "cheap" performance chips on eaby that kid the ecu that the air intake is cold and therefore bump up the fuel flow..They all seem to say "only for cars 1988 onwards".
Why is this? (i have an '85 1.6 gti)
can i use these chips?
Will it bugger anything up long term?
cheers
sorr
I and a few others, thanks guys :), getting rid of an over fuelling issue as it gives a poor running car. So to actively try and cause over fuelling through a 'chip' is not a good idea.
Guest latestarter2
Thats what I thought...so what would be the best cost effective way to provide a bit more oomphh without killing the car??? :)
Guest latestarter2
aah but what if want to remain as original as poss??
Swilki
If your car is a '85 then I'd say fitting a later head and cam ('86 onwards) or going the whole way and 1.9 it.
Guest latestarter2
ok....what about sports air filters do you make much difference?
hengti
^ they don't unfortunately.
imo a four branch manifold (eg. magnex) is about the only 'bolt on' bit that does anything
you're looking at (expensive) head work, cam, alternative induction, engine management etc etc to make any difference otherwise
jshep205gti
Does a later spec head count as a bolt on part?
Cost less than a manifold aswell....
hengti
sorry - i was thinking generally
if the later head goes straight on and gives you the extra 10bhp, then that's got to make sense :(
