Swazy 0 1 Cars Posted February 13, 2007 I ordered new cams from Dbilas for my MI16, they are the 268° ones. Does somebody of you drive them, any expiriences? I´ll use them on a ported and polished head with Gti-6 inlet manifold. Share this post Link to post Share on other sites
Swazy 0 1 Cars Posted February 14, 2007 Nobody has Dbilas Cams in his car? Share this post Link to post Share on other sites
petert 616 Posted February 14, 2007 Without more data it's impossible to make any sort of comparison, except to say I'd be selling the exhaust cam (someone else could use it on the inlet with a vernier pulley) and using a std. exhaust cam with something that mild. Share this post Link to post Share on other sites
Swazy 0 1 Cars Posted February 14, 2007 wich datas you wanna know?. i use an terantex 4-2-1 exhaust manifold, an Gti6- inlet manifold with xu9jaz injectors, standard mi16 cam rod on the exhaust cam, and an xud9 cam rod on the inlet one. ecu is still standard mi16, but will changed very soon. Share this post Link to post Share on other sites
petert 616 Posted February 15, 2007 wich datas you wanna know?. duration @ 1mm or 0.050" lift maximum lift lift at TDC suggested lobe centre angle Share this post Link to post Share on other sites
Swazy 0 1 Cars Posted February 15, 2007 Maximum Lift : 11 m Valve timing: IO/IC - EO/EC 30/66 - 62/26 Lift at TDC: 1,5 mm Peak Timing 108 Share this post Link to post Share on other sites
