Guest ajsik Posted February 12, 2007 (edited) when engine is cold, starts fine idle fine at 1400 rpm. Also it goes smooth in low, mid even high rpm. No revs drops below 1000rpm. no missfiring But once is warmed - it starts to huge missfiring to the exhaust - almost no stable idle revs - engine dies with the huge missfire into to the intake because of very low rpm ... - even I press the throtle pedal, the engine has a big trouble to goes to mid revs (still missfiring), in high revs is noisy... - it is almost imposiblle to start the engine, you have to assist it by throtle pedal and it after a big troubles starts but missfiring ... no "K" light O2 sensor is brand new and good there is a konic filter (JR) AFM itself (wirring may be not) is ok, i measured it before and it gives me good voltage values in all rev range. could any one help ? Edited February 12, 2007 by ajsik Share this post Link to post Share on other sites
jackherer 543 Posted February 12, 2007 sounds like it could be the ECU coolant temp sensor to me. Share this post Link to post Share on other sites
Guest ajsik Posted February 12, 2007 (edited) sounds like it could be the ECU coolant temp sensor to me. the one that is near to SAD, at the back side of head? it is DKZ XU9JAZ engine Edited February 12, 2007 by ajsik Share this post Link to post Share on other sites
jackherer 543 Posted February 12, 2007 yes, thats the one, a blue two pin type. Share this post Link to post Share on other sites
welshpug 1,683 Posted February 12, 2007 yup, thats the one! same symptoms as i had a few weeks ago. bosch part no - 0280 130 026 Peugeot part No 0242 46 Share this post Link to post Share on other sites
Guest ajsik Posted February 12, 2007 thanks guys, I will try it at the afternoon. I am praying to be that coolant sensor ;-). Cuz I need to drive about 150miles to home from college. Share this post Link to post Share on other sites
Guest ajsik Posted February 12, 2007 btw, if anyone has still some other idea what it could be, pls write here, thank you Share this post Link to post Share on other sites
Guest ajsik Posted February 13, 2007 (edited) I've changed the coolant temp sensor and finally it goes nice and smooth cold or warm , i had no more time to take a longer test drive but it seems to be allright. Tommorow I am going home so I will probe it on motorway and in the city. Many thanks for quick and useful help :-) Edited February 13, 2007 by ajsik Share this post Link to post Share on other sites
