TB_205GTI
Tu Cam Specs
TB_205GTI
Does anybody have (or have measured) the specs for the following TU cams?
TU3S
TU3M
TU3JP
TU2J2/TU5J2 (both Rallye)
If my information is corret, the TU2/TU5 should be about 252 deg.
christopher
TU3S
TU3M
TU3JP
252 at what clearance Pete? Answers would be wildly different I'm sure
axnutty
Only info I have - dont know if its of use to you.
TB_205GTI
Cheers, I suppose the duration is at 1mm lift?
Rippthrough
Interesting how far apart some of the inlet timings are, is this down to the cam centrelobe, or different pulleys?
