M_R_205 5 1 Cars Posted February 3, 2007 my engine is currently away geting sexed up and i decided it is worth replaceing all the senors at the same time, i know what all the ones on the block do (thanks too richie-van-gti ) but the now ones on the theromostat housing are taking the piss out of me cheers in advance Paul Share this post Link to post Share on other sites
Ryan 99 Posted February 3, 2007 From left to right: 1. ECU coolant temp 2. Don't know 3. Dashboard coolant warning light switch 4. Dashboard gauge temp sensor Share this post Link to post Share on other sites
M_R_205 5 1 Cars Posted February 3, 2007 no one know what the seccond sensor is??? Share this post Link to post Share on other sites
Bonzai 2 Posted February 4, 2007 seeing as you know what the sensors on the block are, and i cant be assed to search, what are the two sensors on the front of the block above the oil filter? one small one, one big one. Share this post Link to post Share on other sites
Ryan 99 Posted February 4, 2007 M_R_205 said: no one know what the seccond sensor is??? If it was screwed into the bottom of the thermostat housing then I think it might be part of the mi16 aircon wiring. Share this post Link to post Share on other sites
sonofsam 5 Posted February 4, 2007 Bonzai said: seeing as you know what the sensors on the block are, and i cant be assed to search, what are the two sensors on the front of the block above the oil filter? one small one, one big one. Oil pressure sender and warning light. Share this post Link to post Share on other sites
