justinv 4 1 Cars Posted January 31, 2007 So, would like to clear out some small questions about the 205 ecu's 1. What is the difference between a 1.6 and a 1.9 8v ecu ? 2. Once i read in a topic which i can't find, that with bypassing a resistor in the ecu you would de-limit your ECU, any help ? Am sure this is just an easy task for some. thanks Share this post Link to post Share on other sites
welshpug 1,682 Posted January 31, 2007 1) physically nothing, they have a different "map" 2) yes but I dont know the details. Share this post Link to post Share on other sites
justinv 4 1 Cars Posted January 31, 2007 So a 1.9 ecu on a 1.6 does not work right ? any others please ! Share this post Link to post Share on other sites
Swilki 0 Posted February 9, 2007 AFAIK the 1.9 ecus have a shorter injector duration than the 1.6 ecu. The rev limiter thing, pretty simple, just open up the ECU casing and the rev limiting diode is approx 5mm long and the circuit board is marked D701 next to it. The diode is about 50mm from the top left corner of the board. Just cut it out and hey presto, no limiter. Share this post Link to post Share on other sites
justinv 4 1 Cars Posted February 13, 2007 thanks mate, does it work on both 1.6 and 1.9 ecu's??? Share this post Link to post Share on other sites
steve@cornwall 100 Posted February 13, 2007 thanks mate, does it work on both 1.6 and 1.9 ecu's??? Don't think the 1.6 ecu has that diode Share this post Link to post Share on other sites
Ryan 99 Posted February 13, 2007 (edited) The 1.6 ECU does have the diode. I removed it on my old ECU before giving it to a mate to use with a race cam. Edited February 13, 2007 by Ryan Share this post Link to post Share on other sites
steve@cornwall 100 Posted February 13, 2007 The 1.6 ECU does have the diode. I removed it on my old ECU before giving it to a mate to use with a race cam. I couldn't find it...just a space marked on the board- i'll open up another and have a looksee Share this post Link to post Share on other sites
Ryan 99 Posted February 13, 2007 Aren't there a couple of slightly different ECUs for the 1.6? Mine was the one ending in '340' iirc. Share this post Link to post Share on other sites
