swordfish210 20 Posted January 4, 2007 I was just wondering what the average life span is of the TU3 engine without any major work. I was wondering because my XT has now covered 141,000 miles and when i bought it in January with 128,000 miles on the clock it had no history of engine work and in December i has it on the dyno and it was reading 84bhp at the fly with only minor engine mods and it feels and sounds very fresh to drive i.e. no knocks. So what im asking is does it sound like there has been some engine work done in the past or is this just a very fine example of the TU3 engine Share this post Link to post Share on other sites
welshpug 1,681 Posted January 4, 2007 if an engine is serviced regularly theres no reason why it cant rack up the miles without needing major work, as an example my mum's 405 TD only had its head off at 222k due to a leak on the high pressure oil feed, no loss of compression, apart from that its just been servicing, and its now still pulling strongly at 250k. Share this post Link to post Share on other sites
swordfish210 20 Posted January 4, 2007 welshpug said: if an engine is serviced regularly theres no reason why it cant rack up the miles without needing major work, as an example my mum's 405 TD only had its head off at 222k due to a leak on the high pressure oil feed, no loss of compression, apart from that its just been servicing, and its now still pulling strongly at 250k. Nothing new there for the pug diesel engine but the first time i changed the oil in mine it was as black as the ace of spades and it didnt look like it had been changed in a while. Same story with the air filter and i think the fuel filter was the same one it left the factory with. This to me indicates poor maintinance Share this post Link to post Share on other sites
Guest smokinslim Posted January 4, 2007 If i recall correctly my TU was on about 163k when i got it, had had the headgasket done a few times previous and a few minor thing, never anything major. I try to keep up with the maintenance side of things but still drive it hard and its somewhere around 200k now, still going strong. Can't complain anyway. Share this post Link to post Share on other sites
macaroni 17 1 Cars Posted January 5, 2007 Yep, mines done 165K miles and all 4 pots still give 200lb compression. Whilst I cane it on the road I do try and maintain it well. Great engines. Share this post Link to post Share on other sites
Jer309GTi 3 Posted January 6, 2007 My XS engine has done 123,500 miles and still feels spot on. Very quiet (for a TU), and pulls hard to 7000 rpm anytime I want. It has been a well looked after little car, always serviced on time Share this post Link to post Share on other sites
swordfish210 20 Posted January 6, 2007 macaroni said: Yep, mines done 165K miles and all 4 pots still give 200lb compression.Whilst I cane it on the road I do try and maintain it well. Great engines. Is this the correct compression for the 1360cc tu3 engines? Share this post Link to post Share on other sites
axnutty 10 Posted January 6, 2007 I had an AX GT nearing 250K once. The car was shot to hell but the engine went well still! Antifreeze is a big issue on higher mileage TU engines as poor quality or insufficient antifreeze at servicing will corrode the liner seats. They can be damaged through over heating and disregarde to oil change intervals too. Just like any engine. Share this post Link to post Share on other sites
Rob Thomson 6 Posted January 6, 2007 (edited) The engine in my rally car (106 Rallye) has done about 125k now. Spends most of it's time screaming at 7,000rpm and doesn't complain. The head-gasket went a few months ago, and upon inspection with the head off everything was in very good condition. Edited January 6, 2007 by Rob Thomson Share this post Link to post Share on other sites
swordfish210 20 Posted January 6, 2007 well i change the oil every 6,000 miles and i'm using castrol GTX magnatec because its brilliant and i'm running about a 50/50 mix of (halfords) antifreeze and water. I changed the sump gasket at 136,000 miles and the water about a year ago. Other than that i just follow the Haynes manual for the service schedules, Got the 12,000 mile service coming up in 1000 miles time. Share this post Link to post Share on other sites
axnutty 10 Posted January 10, 2007 Well it should be ok if you keep on top of servicing and dont do anything silly. Just out of interest why is Magnatec "brilliant"? Im not saying it isnt, but you seem to be strongly opinionated about it. Share this post Link to post Share on other sites
calvinhorse 870 Posted January 10, 2007 the head i used in my rebuild was 165k and the valves were still tight and is now producing about 100hp! Share this post Link to post Share on other sites
calvinhorse 870 Posted January 10, 2007 Quote Well it should be ok if you keep on top of servicing and dont do anything silly. Just out of interest why is Magnatec "brilliant"? Im not saying it isnt, but you seem to be strongly opinionated about it. have you not seen the advert where the car engine is goin "ouch ouch ouch" as he revs it? well its the same as that, it starts working as soon as you turn the key rather than when its up 2 temp Share this post Link to post Share on other sites
swordfish210 20 Posted January 11, 2007 axnutty said: Well it should be ok if you keep on top of servicing and dont do anything silly. Just out of interest why is Magnatec "brilliant"? Im not saying it isnt, but you seem to be strongly opinionated about it. well 2 of my lecturers at college both used to work as engine builders and were doing a extensive test on road and race oils once spanning about 1 year and with the exception of the super duper expensive race oils the magnatec was coming out top providing the best lubrication in hot and cold condtions and it reduced the wear on the engine compared with other oils. This was enough to convince me to use it and the engine feels much smoother on a cold morning than it did with the silkoline stuff that i was running. Give it a try for yourself and see what u think Share this post Link to post Share on other sites
boombang 2 Posted January 11, 2007 swordfish210 said: i'm using castrol GTX magnatec because its brilliant I've found it to be terrible! After a few thousand miles of heavy usage, it seemed to clump up and become very gunky. I actually had to remove the sump to get it all out, then the next oil change was still a bit manky. I am not the only person I know who's found this either. We wondered if it was the "magnetic" feature of the oil binding together? Share this post Link to post Share on other sites
swordfish210 20 Posted January 11, 2007 nah i'v never had this problem, my oil allways comes out clean and only slightly darker than when it went in the engine and it allways flows out smoothly. Maybe it was just the oil hated ur engine Share this post Link to post Share on other sites
Sandy 191 Posted January 12, 2007 Stick to well known brands and change it as often as you can afford is the best you can do I think. The only "experts" we really get access to have a commercial interest. Share this post Link to post Share on other sites
swordfish210 20 Posted January 12, 2007 sandy309 said: Stick to well known brands and change it as often as you can afford is the best you can do I think. The only "experts" we really get access to have a commercial interest. Like i said the 2 lecturers who did this extensive test on road and race engines were doing it as a test to see what oils they should recomend to their customers to give optimum performance on their engines. So it was a non profit test with a biased result which is why i chose to belive it Share this post Link to post Share on other sites
Rippthrough 98 Posted January 12, 2007 swordfish210 said: Like i said the 2 lecturers who did this extensive test on road and race engines were doing it as a test to see what oils they should recomend to their customers to give optimum performance on their engines. So it was a non profit test with a biased result which is why i chose to belive it Are you sure it was magnatec and not one of their synthetics? Because I would have thought that they would use castrol EDGE 0w-30 for that application. Share this post Link to post Share on other sites
swordfish210 20 Posted January 12, 2007 no they were testing various oils and the magnatec came out top with a cost-performance ratio. If i remember correctly the castrol RS was the best oil they said they tested providing both excelent lubrication and reducing engine wear and drag but i think this is too expensive for a road aplication. Especially for a student like me. Share this post Link to post Share on other sites
