hengti 2 Posted December 12, 2006 Hi I've traced a coolant leak on my '91 1.9 to the low coolant sensor switch that is screwed into the bottom of the expansion tank. Picture : The problem is with the seal shown to the side. Peugeot don't sell the seal seperately, but do keep the sensor, which is a shocking £45.. I'm going to pop down to B&Q and see if I can use an ordinary o-ring. The original seal appears to be shouldered though - can I ask, does anyone have any of these seals or any ideas about what else I could try if it doesn't seal? Whilst I'm at it, I thought I'd replace the short hose that goes from the side of the thermostat housing to the device underneath the distributor (the SAD - ?). My dealer hasn't been able to find a part number though. Can anyone advise? Related picture : Thanks all Share this post Link to post Share on other sites
Powers 13 Posted December 12, 2006 Why not change the expansion tank for a clear one, where the low coolant lever sensor is at the top. As regards to that hose, try a wanted add. Share this post Link to post Share on other sites
nick 3 Posted December 12, 2006 Or go to the scrappers. They must be used on all sorts of Pugs, 405, 309, 205 etc... Nick Share this post Link to post Share on other sites
hengti 2 Posted December 12, 2006 thanks for the replies i've had problems with used coolant hoses before and would prefer to use a new one - i'll try another dealer a little later in the week if anyone does know the part number though, that'd still be appreciated i've put a new 'o' ring on the level sensor - it seems ok, but i guess time'll tell Share this post Link to post Share on other sites
sonofsam 5 Posted December 12, 2006 Quote The original seal appears to be shouldered though - can I ask, does anyone have any of these seals or any ideas about what else I could try if it doesn't seal? I would say maybe take the original 'o' ring to a specific plumbers centre or even Covers, if you have no luck with part no. Just a guess though , but would of thought the 'o' ring would come as part of the sensor? ( I need a new one also ) Can I ask, did you notice water dripping out of there onto the ground? Have a slight leak somewhere myself Share this post Link to post Share on other sites
hengti 2 Posted December 12, 2006 thanks for the suggestion - i've subsequently wondered if the 'shouldering' is just a by-product of the seal having been compressed in the joint - still not sure i have been told that a new seal does come with a new sensor - i'm not too fussed about the operation of the sensor though and would gladly do away with it if banking plugs were available - it seems that the only 'genuine part' option is a new sensor&seal at £45 .. a little pool of coolant had collected inbetween the casting ribs on the gearbox underneath the distributor (presume that's g'box under there anyway), which is what led me to investigate in that area. it's a bit fiddly, but you'd probably be able to identify a leak from that area by feeling for moisture from the joint. it looks a crappy design too - it just twists on like some of the bulb holders! Share this post Link to post Share on other sites
Phil H 16 Posted December 12, 2006 I have that hose that the dealer got me in error...you want it? Still sealed in the bag. Share this post Link to post Share on other sites
hengti 2 Posted December 12, 2006 Philip Hills said: I have that hose that the dealer got me in error...you want it?Still sealed in the bag. "back of the net!", as Alan might say that's very good of you - thanks; I'll pm you Share this post Link to post Share on other sites
