S33GAV
Have Replaced My Mi Box
S33GAV
Hi
I've recently replaced the 1.9 box in my miami with an mi16 box (thanks sorr) using Jonmurgie's guide (thanks), however after reconnecting it all up I seem to have missed something, as I get nothing when I turn the key. The battery is charged but I got no spark when I connected the connectors?! (which means the earth wires aren't connected?!)
I didn't remove the starter motor, all I did was disconnect/reconnect the 3 bolts holding to the gearbox. Sean removed all the wiring/connectors and I've tried to reconnect it all but something must be missing.
I've got a couple of photos, the first one is showing the earth wire from the battery, my question is, should there be another earth wire in the top hole?
Second photo shows the lead coming from the +ive connector on the batter, and there seems to be a loose wire and I'm not sure where this should go, if anywhere?! (Can't remember what it was like before I removed it, it was so long ago).
Any help much appreciated
Gav
mos
hi,
you wont get a spark anyway until the starter is turning as the ingintion system wont be active
the yellow wire in your hand in the photo may have come loose from the little power distrubtion block that mounts in front of the battery, attached to the slam panel (little black plastic box)
alternatively it could be the direct feed to the starter from the battery but the wire does not look long enough to be that
mark
Edited by mos
smighall
I'm sure there should be another earth on the gearbox?
smckeown
That yellow wire doesnt look familiar. Does the tape look old or new ? Are there any more wires dangling about ? That top hole, does it look fresh ? indicating something was there recently ?
ablister
you could use a jump lead to earth the engine to the body and that would be an easy test for a bad earth
S33GAV
Spot on, nice one!! That yellow wire had indeed come loose from the power distribution block, so thanks very much for that!!
Cheers to all for your responses
Gav ;)
