pugpete1108
Oil Pressure Adaptor Piece , Who Did It?
pugpete1108
guys , saw this pic posted a while back about a take off pipe for the oil presure guage /warning switch for an xu10j4rs engine , cant for the life of me find the post and cant remember who posted it :)
i have been to my local hose supplier and he cant supply me with the parts for this set up , so can whoever posted tbis please let me know where they brought them from so i can do it to mine?
cheers
pete
sonofsam
Is it a Brass T-piece adaptor your after ( I cant see the pic ) Can now!
If so I got mine from demon Tweeks:)
Edited by sonofsam
miamistu
Don't know who did it first but there's normally a couple knocking about on ebay. :)
smckeown
thinkauto also supply these
sonofsam
Don't know who did it first but there's normally a couple knocking about on ebay. ^_^
Cheaper from DT ..:)
Search 'LMA' T-piece
Seem to be M16 x 1.5 on the big thread in the block, and the oil-pressure sender from the XU9 engine is M10 x 1.0. is the size I beleive according to BlackMi16:D
You need a big crush washer also, otherwise it leaks out the block :)
Edited by sonofsam
B1ack_Mi16
Cheaper from DT ..^_^
Yup, that's the correct threads.
Had to double-check now as the eBay one seem to be M14 and 1/8 BSP threads.
smckeown
i'm just changing from the mechanical thinkauto oil pressure early warning system to my KMS ecu controlled. For this I need to change the thinkauto variable sender on the bottom with a VDO 0-10 bar one.
This is the pic before i change the variable sender.
Sam
Why not just cut out the overly expensive middle man (dt) and go direct to le mans? They're bound to be cheaper.
Sam
:) thats a first. Tweeks not wacking excess dosh on, shock horror. However, going to your local halfords might help, they deal with Lemans, would save on postage.
sonofsam
Truth...But I could make one thinking about it:D
pugpete1108
just got in from work , you lot are legends , is there nothing you dont know :)
cheers
pete
sonofsam
Yes. How Womens brain's function :)
