Guest doggybs
Funny Gear Box Noise
Guest doggybs
Hi All,
This morning my Mi16 developed a strange gearbox problem. In second / third gear, when I back of the throttle I get a bouncing grating noise, and load of vibration through the floor. Sound serious :-(. Changing gear and acceleration is fine, only when back of power.
Any ideas?
James.
Guest doggybs
So basically happens when rolling in gear, ie upto junctions, etc.
could be the exhaust hitting a heatshield... either because it needs readjusting or because the engine mounts are going soft.
Guest doggybs
Nar, isn't that. The car is actually bouncing / jerking while its make the grating noise. Its very strange.
Guest doggybs
After further investigate its prob the drive shaft or sumit courseing the problem. I just jump to the worst conclusion.
Cheers for your input.
James
Guest doggybs
Jackherer, you the man. That was exacty what the problems was. Look how mashed this mount is.
Cheers.
