pugbliss 0 Posted November 17, 2006 quick question but how the hell do i get the door pins out to replace them??? also how/what is the best way to get the check strap pin out as it looks kind of frigile so hitting with a hammer looks a no no??? any help appriciated Share this post Link to post Share on other sites
welshpug 1,678 Posted November 18, 2006 hammer and punch/drift, only way! one good tip, remove the door! you can then smack them without fear of denting the door. Share this post Link to post Share on other sites
Super Josh 4 Posted November 18, 2006 (edited) Check strap, just use a hammer and pin punch as above. For the door pins, Draper sell a tool for the job, around £10 - £12 here. You can then do it all in situ, just get an assistant to support the door and use a jack and a piece of wood too Josh Edit Just found it for £7.99 here. Although it comes out at £12.94 with the P+P, it means you effectively getting free P+P if you can't find it locally or like armchair shopping Edited November 18, 2006 by Super Josh Share this post Link to post Share on other sites
