hodgy 0 Posted November 2, 2006 im doing a complete phase1 to a phase2 engine swap (1.9 gti) for the gear box ive got clutch pedal,cable and the right clutch to put in as for the engine is the amplifier and coil any different? i think the wires for the starter motor and alternator are different but im gonna use my old ones.i know the water bottle is a different shape but can i still use my old one?and will the pipes and everything still be ok to use any help would be apreciated lee Share this post Link to post Share on other sites
steve@cornwall 100 Posted November 2, 2006 hodgy said: im doing a complete phase1 to a phase2 engine swap (1.9 gti) for the gear box ive got clutch pedal,cable and the right clutch to put in as for the engine is the amplifier and coil any different? i think the wires for the starter motor and alternator are different but im gonna use my old ones.i know the water bottle is a different shape but can i still use my old one?and will the pipes and everything still be ok to use any help would be apreciated lee If you just disconnect pipes and wiring from your old unit- they'll just plug back in in the same place. I believe there may be some issues with the adjustment of the gear shift link balljoints in going from be1 to be3 box, I've used the links from the 'box of the donor 1.9, so can't be of more help on this! Share this post Link to post Share on other sites
vince 0 Posted November 2, 2006 I've no experience, but the reverse gear on BE1 and BE3 are not at the same place on the grid and are not selected the same way so as steve@cornwall said may be a good idea to use the gear lever and linkage from the BE3 gearbox... vince Share this post Link to post Share on other sites
hodgy 0 Posted November 4, 2006 ive got the stick n linkages for the swap. Share this post Link to post Share on other sites
