Theo205 0 Posted October 25, 2006 Hi I had change my std. 70amp alternator a couple of years back with a 405 90 Amp but yesterday i noticed that the alternator housing has cracked where the big fat bolt holds it, the belt went loose and now i have loads of squeeling noise from the belt. Instead of changing the alternator housing i prefer to go and find anotherone from a Pug breaker yard but the problemis that 205 gtis and 405's are not easy to find . I'd like to ask if any of you know whether any other Peugeot alternator will fit on my GTi. 306 maybe? :S Thanks Theo Share this post Link to post Share on other sites
welshpug 1,683 Posted October 25, 2006 best bet is to take it off and have a wander round some scrappies, but basically any engine that uses the same configuration (pas, a/c or none as the case might be) will most likely use the same bolt config. when my brother needed one for his 306 DTurbo we just took it with us and said "got one like that?" it worked! Share this post Link to post Share on other sites
Richie-Van-GTi 74 2 Cars Posted October 25, 2006 more or less any pug/cit alternator will fit, just a case of finding one with the right pulley for the belt Share this post Link to post Share on other sites
kyunis 0 Posted October 25, 2006 Is the 1.9 diesal the same alternator. As i may have a spare one. But posting to cyprus may be expensive. Share this post Link to post Share on other sites
Richie-Van-GTi 74 2 Cars Posted October 26, 2006 1.9 derv will bolt on but it has more grooves in the pulley than the gti one. Fairly certain it would still dive on the thinner belt, or swap the bottom pulley on your gti lump for one of a derv and get the wider belt Share this post Link to post Share on other sites
mickie 3 Posted January 9, 2007 Richie-Van-GTi said: 1.9 derv will bolt on but it has more grooves in the pulley than the gti one. Fairly certain it would still dive on the thinner belt, or swap the bottom pulley on your gti lump for one of a derv and get the wider belt it does work.. but i may do what you've said and get the 405 belt too.. my cars a 1.6 xu5ja and the alternator thats just gone was 70amp but isnt mine supposed to be 50amp ? anyone know ? and will my diesel 405 55amp alternator be ok on my car ? sorry for hijack cheers for any help Share this post Link to post Share on other sites
welshpug 1,683 Posted January 9, 2007 yup, should be fine. a bigger alternator just means it'll be working at less % of its capacity to run the electrical systems, therefore in theory being more efficient, similarly with a bigger battery. Share this post Link to post Share on other sites
mickie 3 Posted January 9, 2007 thanks for the fast reply.. i think the 405 alternator looks much better than the old 205 one.. looks to be made better.. do you think it'll be more reliable tho ?? haha maybe not as its french Share this post Link to post Share on other sites
