speedyandy 0 Posted October 24, 2006 strange thing started my car for a bit was working fine went in had dinner come back out and tried to start it again, it will turn over and try to start but refuses to start. removed the AFM and it starts alough running a bit rough, i also found a rogue white wire thats on top of the inlet manifold it's got a spade connector on it but no place for it to connect up to Any suggestions?? Share this post Link to post Share on other sites
chris1986 1 Posted October 25, 2006 i would like to know what that wire is about mine isn't connected to anything but runs fine....., not the obvious like out of fuel as this can couse this sometimes as it trickles down the pipe. good luck Share this post Link to post Share on other sites
steve@cornwall 100 Posted October 25, 2006 chris1986 said: i would like to know what that wire is about mine isn't connected to anything but runs fine....., not the obvious like out of fuel as this can couse this sometimes as it trickles down the pipe. good luck ph2 cars I take it? with the coil mounted on the inlet manifold? White wire does nothing, unless you've got pug diagnostic computers I believe! It's purpose has been posted before, but I can't remember! Share this post Link to post Share on other sites
speedyandy 0 Posted October 27, 2006 Thanks yes it is a phase 2, Still stumped on the afm tho, i will give it a clean with carb cleaner and give it another go. Share this post Link to post Share on other sites
