roland rat 11 Posted August 29, 2006 ive got a full magnex system for my 205 gti to fit and after the centre box started to blow i feel nows the right time to put it on the car.the only issue i have is how will removing the cat affect my car?will it run lean/rich as the lamaba sensor is not fitted?any other possible gremlins that could turn up due to me fitting the exhaust? thanks ashley Share this post Link to post Share on other sites
welshpug 1,678 Posted August 29, 2006 youll need that lambda sensor fitted for it to run properly, plus you'll fail the MOT... Share this post Link to post Share on other sites
roland rat 11 Posted August 29, 2006 youll need that lambda sensor fitted for it to run properly, plus you'll fail the MOT... mots months away ill worry about that another time .if i dont fit the sensor how will the car run? (no place on the magnex manifold to fit it to!) Share this post Link to post Share on other sites
welshpug 1,678 Posted August 29, 2006 get a boss (read suitably sized steel nut) drill a hole and weld it on, job jobbed. Share this post Link to post Share on other sites
roland rat 11 Posted August 29, 2006 that sounds like too much hard work!!! only joking.thanks for the info mate Share this post Link to post Share on other sites
sherly 0 Posted August 30, 2006 mots months away ill worry about that another time .if i dont fit the sensor how will the car run? (no place on the magnex manifold to fit it to!) How old is the car? I decatted mine and it's passed every MOT since (4 years) - on a Dec92 K reg. I also had a full magnex exhaust fitted at one point - I managed to fit a stainless lambda boss onto the manifold (on the collector section I recall). It is very tight for space but it fitted. Once I had drilled the hole and pushed the boss into place I got a local fabricator to TIG weld it in position. Mart Share this post Link to post Share on other sites
roland rat 11 Posted August 31, 2006 How old is the car? I decatted mine and it's passed every MOT since (4 years) - on a Dec92 K reg. I also had a full magnex exhaust fitted at one point - I managed to fit a stainless lambda boss onto the manifold (on the collector section I recall). It is very tight for space but it fitted. Once I had drilled the hole and pushed the boss into place I got a local fabricator to TIG weld it in position. Mart its on an l-reg aug 93'.i might look into buying a 'sports' cat and mix it with the magnex system and manifold.how close is your 205 on the emmisions test? Share this post Link to post Share on other sites
