Sam
Radiator Inlet/oulet Dimensions (gti)
Sam
I'm thinking about getting an alloy radiator made up while I'm over here (providing it's not too expensive!) I have a guy to email dimensions to but I had a question.
What size are each of the inlet/outlets?
smckeown
eh? what's wrong with the nissens ali rad ?
Sam
The TD one (which I'll need) costs a fortune anyway (£80), I can probably get a FULL alloy (not just a core) one for £120 over here.
Whats the point in getting a Nissens one then? :blink:
engine killer
forgive my asking, is the nissens ali radiator a direct replacement? is the dimension exactly same as the stock one?
thanks. :blink:
Sam
Yep its just an OEM replacement, not uprated or anything.
Jonmurgie
Except the Nissens are aluminium and lighter than the normal 205 ones :blink:
James_R
Any particlular supplier?? mines started leaking a little
cybernck
i've recently had the larger rad made and the connections were 32mm.
make sure you double check that though ;).
make sure you double check that though :wacko:.
I've just measued the sizes on a spare (nissens) radiator Ihave downstairs & the are 32mm. ;)
Graham.
