westy 0 Posted August 1, 2006 Hi, Trying to get my heater blower to work at the moment - currently it works whenever I disconnect the contact board (behind the knobs) it works, but whenever I plug in the board (5 pin connector) it stops... any ideas? Ben Share this post Link to post Share on other sites
Guest 205_dave Posted August 7, 2006 When you disconnect the fan control does the fan run at full speed? a mate had this problem with his 205, replaced the fan and this cured it (there is a circuit board on it which is the variable speed for the fan). Share this post Link to post Share on other sites
Matt Holley 11 Posted August 7, 2006 (edited) I had this when I got mine,if you look down by the fan and find the wires that go to it and follow these towards the centre consol one of the wires goes to a black box that screws up by the fan I think its called a reostat? (sp) mine was nackerd and I had the same fault as you Edited August 7, 2006 by matt holley Share this post Link to post Share on other sites
westy 0 Posted August 11, 2006 205_dave said: When you disconnect the fan control does the fan run at full speed? a mate had this problem with his 205, replaced the fan and this cured it (there is a circuit board on it which is the variable speed for the fan). The fan doesn't run at full speed, about half speed I'd say. How easy is it to access the heater fan? Thanks. Share this post Link to post Share on other sites
