Wurzel 16 Posted July 26, 2006 I've had a look at it and I reckon there is a special tool that removes these mounts. Being Pug owners and skint, how have other people removed these mounts using 'normal' tools? Share this post Link to post Share on other sites
Jonmurgie 2 Posted July 26, 2006 I use a chisel and hammer to tap it around until it's loose enough to remove by hand... rubbish design really! Share this post Link to post Share on other sites
Anthony 1,003 Posted July 26, 2006 I use a chisel and hammer to tap it around until it's loose enough to remove by hand... rubbish design really! Ditto, except I usually use a large flat blade screwdriver for the job - quite simple usually Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted July 27, 2006 There is a special tool for it & its shown in the old haynes manuals but the above methods work just as well, at least I hope so as Ive got one of the BakerBm group N engine mounts to fit on mine sometime. Graham. Share this post Link to post Share on other sites
hd_andy 2 Posted July 27, 2006 Ditto, except I usually use a large flat blade screwdriver for the job - quite simple usually Same here! Share this post Link to post Share on other sites
Wurzel 16 Posted July 28, 2006 Just as I though, cheers guys Share this post Link to post Share on other sites
Edd-XS 0 Posted August 4, 2006 As usual the search function on this forum has supplied a swift end to an annoying problem. Ta! Edd Share this post Link to post Share on other sites
