Guest DocBurble
Stuttering/snatching/misfire?
Guest DocBurble
Perhaps you guys (and gals) can help me sort out a problem with my 1.9 Gti.
For a while the engine has been snatching back violently while driving along especially when on the last 1/4 of the fuel tank. I've searched the forum but no-one seems to have had the exact same symptoms.
So far I have: -
Replaced and gapped the plugs
Replaced the dizzy cap & rotor arm
Swapped the fuel pump
Replaced the tachymetric relay
Checked continuity in the fuel pump connector block supply and earth wires
Cleaned all the debris from the bottom of the fuel tank
Replaced the SAD
Checked the Co2
Checked the TPS set up
Replaced the fuel filter
Checked the voltage to the fuel pump both sides of the block
The strange thing is the stuttering is momentary, the engine doesn't die it just snatches several times in a row but will still tick over happily and I can usually still carry on accelerating despite the stutter.
What should I check next?
DocBurble
Rob_the_Sparky
If it is doing it under hard acceleration then I'd try coil and igintion amp. The ignition needs max power (voltage actually) to get a spark under max load so mis-fire under max load is usually a sign of a weak coil or ignition amp.
Rob
Pug_101
Someone had a leaking fuel pump which gave your sort of problems. The leak was a split hose inside the fuel pump itself (which sits inside the tank), maybe worth a look.
Can't find the thread with a quick search, but it out there :unsure:
Guest DocBurble
Rob
The misfire happens under small to medium throttle openings not full throttle and I'm trying to work out why it should mostly happen on the last 1/4 of the tank
Sounds feasable but I've already taken the pump out changed it and tested the replacement.
Guest DocBurble
Also I forgot to mention that the rev counter is steady as a rock through all of this.
Pug_101
Have you checked fuel pressure and vacuum for air leaks?
Doof
So many of these topics popping up recently with varying misfiring symptoms. Be sure to post back your findings when you fix it because im in the same boat. :D
Guest DocBurble
You are a winner!
I did 'check' the main vacuum pipe from dizzy to throttle body a while ago but due to its buried route from one to the other I didn't remove it to inspect it properly.
Yesterday as I removed the end from the throttle body 5-8mm was left behind confirming it was perished and most likely split. A quick replacement and bye bye misfire!
All the other little jobs at the top of this thread are well worth doing and have certainly helped smooth out and improve the power delivery but the air leak was the real culprit.
Also worth noting for the record was the slighly higher water temp problem I had which with hinesight (sp?) now makes perfect sense.
