Guest ashnicholls Posted July 13, 2006 (edited) Anyone know where i can get a top dead centre sensor, for a 1.6 carb engine. And a new crank pulley and bolt. Just tried GSF and they have not got either. Cheers Ash Edited July 13, 2006 by ashnicholls Share this post Link to post Share on other sites
sonofsam 5 Posted July 13, 2006 www.find-a-part.co.uk www.partsgateway.co.uk www.247spares.co.uk www.silverlakeautoparts.co.uk www.breakerlink.com Share this post Link to post Share on other sites
Guest ashnicholls Posted July 13, 2006 ok cheers, but i want new parts? Share this post Link to post Share on other sites
pug309twin40s 1 Posted July 13, 2006 peugeot dealer will be the best to get the proper bolt and washer for the crank pulley. TDC sensor? not sure what this is? Share this post Link to post Share on other sites
miamistu 1 Posted July 13, 2006 Online dealership: http://www.planetpeugeotparts.com/ Share this post Link to post Share on other sites
sonofsam 5 Posted July 13, 2006 Top dead center sensor- i have a GTI one on the 'bay at the mo..not sure if its the same as a carb model. Share this post Link to post Share on other sites
Guest ashnicholls Posted July 13, 2006 its a little black tube, that has a bracket with a wire on it, that detects the cut out in the flywheel as far as im aware. i thought that was the top dead centre sensor, the wire has worn through on it, so thought it would be best replace it. will pop in peugeot garage tomorow then. Cheers Ash Share this post Link to post Share on other sites
Guest ashnicholls Posted July 14, 2006 got them sensor was £16 + Vat bolt was £2 + Vat. and for the pulley i was quoted £136 + vat. thats never right? so think i will just clean up the one i have got. Share this post Link to post Share on other sites
Miles 331 1 Cars Posted July 14, 2006 I was going to say, No point of fitting the sensor as no one uses it, Not even the Pug Garage, Most just use a timing light from Snap On Share this post Link to post Share on other sites
Guest ashnicholls Posted July 14, 2006 hows that work? so you dont need the top dead centre sensor at all to drive the car? Share this post Link to post Share on other sites
Miles 331 1 Cars Posted July 14, 2006 Not at all, Not used on the XU carb engines or Injection engines even, Only the Motronic ECU'd car's mainly use the TDC sensor which bolts into the gearbox and reads a toothed flywheel which again the basic XU's do not have Share this post Link to post Share on other sites
Guest ashnicholls Posted July 14, 2006 eh? that does not make sence, the block i have is an XU carb engine. Which has a little black tube with a wire coming of it, with its own bracket that connects to the block. which as far as i no reads a single hole in the edge of the flywheel? Share this post Link to post Share on other sites
steve@cornwall 100 Posted July 14, 2006 ashnicholls said: eh? that does not make sence, the block i have is an XU carb engine. Which has a little black tube with a wire coming of it, with its own bracket that connects to the block. which as far as i no reads a single hole in the edge of the flywheel? Isn't it just for diagnosis? If your pug techies can be arsed to drag out and dust down that rig they charge you for but never use? (I'm not bitter about a past bill, surely?) Share this post Link to post Share on other sites
Miles 331 1 Cars Posted July 14, 2006 The sensor does mount there, But it's for outdated Pug Dealer Diag machine if they have it now, Most use a snap on timing light. So to sum it up, The sensor is not used by the engine and I dount by any Garage Share this post Link to post Share on other sites
