P_205GTi 0 Posted June 23, 2006 ok when my car is at idle the dash and whole car vibrates alot and then dip the clutch and then it stops and there is a weird tapping noise when you let the clutch out again . now ive had this before when my gearbox came away from the engine but i fixed that 2 months ago. could it be this again or a wrecked lower mount? help please Share this post Link to post Share on other sites
Guest cknotty Posted June 23, 2006 My XS makes the same sort of noise (though not as much vibration) at around 500rpm (used to have overreading tacho), and it's got a knackered bottom mount too, so it may well be that. Have to get around to sorting out an uprated one... Share this post Link to post Share on other sites
t16ryan 1 Posted June 23, 2006 sounds like same fault maybe lower mount, check your gearbox bolts are all tight, if the box has been fitted without dowels the bolts work loose, Share this post Link to post Share on other sites
Richie-Van-GTi 74 2 Cars Posted June 23, 2006 sounds to me like dodgy thrust bearing or input shaft on the box, both could of been damaged by previous problem. Share this post Link to post Share on other sites
scotthall39 0 Posted June 24, 2006 Sounds like the mount playing up. Better have a look before it gives up the ghost while driving. Share this post Link to post Share on other sites
Guest CB-Dave Posted June 26, 2006 mine did the same thing after the box and block tried to part company, swiftly followed by a loud bang and no drive as I'd torn the centre out of the clutch friction plate... Share this post Link to post Share on other sites
Enfield 0 Posted June 26, 2006 I had this with my GT. I think you need to adjust the clutch cable mate. Share this post Link to post Share on other sites
nick 3 Posted June 27, 2006 I had the exact same symptoms as this, with the exact same conclusion as CB-Dave. Nick Share this post Link to post Share on other sites
