Guest Tidybri
Electric Windows
Guest Tidybri
Has anyone got a diagram i can work from for electric windows as i cant work out which wires go where now its all apart.
I know i should have made a note where they came from but we live and learn right!! :P
Greenys_meanies
Yeah i got haynes version, and should be able to help, i custom fitted my leccie windows. pm me with your email, i'll scan the diagram and send it to you.
Cheers Daz
Edited by Greenys_meanies
Guest Tidybri
yeah i have a haynes but which wires are which? not coulor coded just codes? :D
Greenys_meanies
the codes you are looking for are printed on to the wires near the ends (plugs) and maybe in the loom aswell.
the diagram is quite simple when you get your head round it (haynes seem to make it harder! lol)
right here we go, the single passenger switch controls it own motor only, has a 12v feed, and 2 wires from the drivers side.
the drivers side switches are a bit harder. the passenger window one has a 12v feed, 2 wires are earth and 2 wires that connect to the passenger side. the drivers window has 2 earths, 1 12v feed, and 2 wires to the motor.
the 2 wires that go across the car ar configered so that when the drivers switch is not pressed the 2 earths are sent to the passenger switch(called motor lock) and allows the passenger switch to work. if the driver presses the pasenger switch then 12 and earth are passed down the 2 wires and operated the window.
what exactly was your problems with you windows?
Guest Tidybri
my original problem was my passenger window didnt open from either switch, now none of them work lol :D
Greenys_meanies
i'm gonna answer your questions on your other post, if thats ok
Daz
