205_sunderland 4 Posted June 10, 2006 is it posssble to fit a mi16 head onto a bx gti 8v block straight swap? im curious but i kno the bx engine has high compression so i wounder if it would fit and would all the oilways etc meet if i could regards michael Share this post Link to post Share on other sites
Rob Turbo 3 Posted June 10, 2006 AFAIK the oil ways etc line up, but the valves would hit the pistons I think, you would need mi pistons and liners Share this post Link to post Share on other sites
whizzer71 0 Posted June 10, 2006 The 8 V bx doesnt have the piston spray bars either,its a totally different engine !,Just swap the lot ! Tris Share this post Link to post Share on other sites
205_sunderland 4 Posted June 10, 2006 so i definetly couldnt use me bx gti bottom end? what about a 19 gti end? Share this post Link to post Share on other sites
Miles 331 1 Cars Posted June 10, 2006 Yes you can use any XU bottom end, Most likey the valves would clear but as with previous post the engine mounts etc need modding to fit so it's not worth the hassle. Share this post Link to post Share on other sites
205_sunderland 4 Posted June 10, 2006 oh well i though it was worth a try as a cheaper alternative as there isnt many good mi16's left these days Share this post Link to post Share on other sites
petert 611 Posted June 11, 2006 I haven't measured one, but I would have thought the valves would be guarenteed to hit the pistons. Your CR would be well down anyway. Assuming you changed the pistons, the biggest issue is the front engine mount. Only 3 of the 5 holes match on an 8V block. So if you're prepared to hold it up by 3 bolts go for it. I'd like someone to be a ginuea pig! Share this post Link to post Share on other sites
