Guest jock_26
Compatible Conrods
Guest jock_26
Hi,
Rebuilding s16 engine and was wondering what conrods are compatible with this ? Does it make a difference if g/pins are pressed or circlipped. Using the crank from gti-6 with three s16 rods pistons complete. :ph34r:
Guest jock_26
Anybody got a spare s16 conrod?
Bonzai
as ive learned from experience, you can get rods from a same engine type, but they may not be the same weight. i sourced a replacement which was 30g lighter than the 3 original rods from my Mi project
TB_205GTI
Nope, but I've got four EW10 conrods and pistons, if you can use that :D
No conrods are compatible. The XU10J4 conrods are unique to the S16 and 2L Mi16. Later XU10 engines have pressed pins and I'm unsure of the lengths.
