steve@cornwall
Replacing Cti Roof Covering
steve@cornwall
Bought one of them £75 pvc roof coverings off ebay about 6 months ago and keep putting the fitting off in case i naff it up! I've got myself some new cables made up, all new ss screws/nuts and impact adhesive (all marine grade from chandlers- £15 !!! how much from pug?). I've even stripped a knackered one to see how it all fits together. Even got a mint rear fixing bar and rear window section from a swap with a t.diesel rad and a couple of bumpers! Got one good rear stiffener and one home made one. Posting for a N/s stiffener or anyone know a supplier?,discontinued part
Has anyone done this who would give me some tips/pitfall warnings, please as I don't have any instructions.
NOsMAN
http://forum.205gtidrivers.com/index.php?s...953&hl=cti+roof
follow that link..
ask PHILcti as he has done one before ..
I have bought one of PIGLETT as well which cost me £160 which included a brand new rear window which zips out..
gonna get mine done proffesionally incase i bodge it B)
Found a local fitter so hopefully it wont be too much(quote i had of him was £350 fitted and thats including the roof and rear window)
PhilCTI
follow that link..
gonna get mine done proffesionally incase i bodge it :mellow:
Hi Steve,
I've put a new roof on recently, if you look on my link you can see it.
It is worth planning it out in which order everything has to be done, the only thing I could of done better was to finish the inner headlining before putting the new outer roof on, as it meant reaching awkwardly between the two with a rivet gun to finish off holding the headliner in place. I've repaired and reused the original rear window for now and will look to replace later, the only other problem I had is it took quite alot of jiggling around to get the roof to sit in the correct position to get the windscreen end clamps to connect properly.
I do have a copy of the instructions, if you pm or email me I'll sent it to you ,
Phil
Phil H
I think I am just going to send mine to the local trimmer who has quoted £225 labour.
