Jez G
Distributor Lead Pulled Apart !
Jez G
Help !!
The above pictures are from the lead going into the distributor from the ingintion module, I have managed to pull the wires out of the black connector. :P
I have no idea which wires go back in which hole ... :)
The black connector is numbered 1, 2 and 3. I have a red wire a green wire and a braded eath.
Can someone please tell me the correct wires to put back in the right holes ....
Thanks in advance
Jez
Jez G
Anyone ?
I am a bit reluctant to ramdomly try in case I do more damage !
If not I will try to get my local Pug dealer to help ... or sell me a new bit of harness.
The car is off the road until I can sort this out.
Jez
I've got this at home afaik on the loom I removed from my car when I fitted the MP3.1.
I'll look later & let you know.
Jez G
Many Thanks
Jez
Picture attached, spring clip facing you & they run Black (braided cable), green red left to right.
Checked the loom I have & a p;ug that i got from a scrapyard ages ago that I'd forgotten I had.
Jez G
Graham, thanks, hopefully the thing will start now, once I have sorted this out
Jez
Edited by Jez G
Jez G
Worked a treat .... thanks again Graham, it started first turn of the key !!!
... now of for an mot, and no doubt more problems !
Jez
