Guest Big Daz
What Spark Plugs?
Guest Big Daz
We are currently running approx 50 - 75 bhp Nitrous Oxide shots on our track car (progressive controller), but it appears after 4 hours of track time on Saturday that a tip has melted on one of the plugs. What plugs could I use that are stronger & run cooler? Just got std ones in atm
Daz
jonD6B
It's a tough one beacause you're not running the same temps. all the time. Do a Google search on plugs and see what comes up. Try looking at the NGK and Champion ranges. I drive hard all of the time and I use Bosch 4's without any issues.
j_turnell
I know Greenmachine off here (Mike) ran nos on his goodwood and used some HKS plugs iirc, quite expensive though.
Guest Big Daz
Can anyone tell me what plugs are std in the 1.9?
ngk number or something similar?
Daz
Ryan
Those HKS plugs are just re-branded Denso plugs, which HKS just print their logo on and sell for 5 times the price.
I wouldn't let them near my car. One fell apart inside my mate's 200sx and cost him £5k. The same thing happened to somebody else a few months before as well. B)
Edited by RyanMoore
base-1
Std NGK plugs for 1.9 8v are BCP7ES if I remember right. Don't go anywhere near Bosch Super 4's, they will most likely kill your engine when you use the gas.
Cheap and simple upgrade - std ERST plugs, BC8ES, should cope OK
Guest Big Daz
Whats ERST mean?
BC8ES - Is this a NGK type?
Darren
I know that Wizek used to swear by Iridium tipped plugs when he ran a lot of gas. They are not cheap though. http://www.spark-plugs.co.uk/pages/technic...spark_plugs.htm
  Quote
Denso Iridium tip - click to enlarge
Notable properties of Iridium are its melting point - approximately 2450 degrees C
Guest Big Daz
Ok, I have ordered some iridium ones, heat range 9 so 2 ranges cooler than current ones. We will give them a go & see
Daz
Bally
Champion's C57 or C59, . C57 being the colder plug, equivalent to a ngk 10. I run c57 with my Nos with no problems.
But you may also be running too much advance.
If you are melting plugs, you will soon damage a piston..
Martin@PRD
I have also used denso .4 plugs, never had a issus running with Gaz
base-1
  Big Daz said:
Whats ERST mean?
Darren
Escort RS Turbo, sorry.
They're about 2 quid each, unless you are running silly amounts of nitrous you really don't need to spend 100 quid on spark plugs.
