Guest Red205
Xu Engines
Guest Red205
How hard is it to mount a Xu or mi16 uprite like the ford yb or atleast to 7 degrees like the vauxhalls??....i would like to keep my rwd pug mainly pug but fitting the Xu engine is a pain.
thanks.
Jonmurgie
To have it upright I'd guess you would need to go dry sump as the oil pump and sump are designed to work with the tilt of the engine... there were pictures of a longmans Mi16 posted on here last week and that was mounted perfectly vertical, looked very nice like that but was dry sump :)
It's one of the reasons that the Mi16 isn't used in kit cars (Cater/Fields etc.) as they are too tall with their sump etc. and the angle makes it hard to fit... hence the ford/vauxhall engines are usually used.
Sandy
The XU block also lacks "side" engine mounts and a bellhousing is almost unobtainable.
Guest Red205
does anyone have any pics of both sides of the blocks?? Are they any holes on each side that can be used???
so can i modify the sump to make it as shallow as possible and wing the sump to get back some of the oil capacity??
Edited by Red205
Jonmurgie
Oh it's no doubt doable... just how much time and money you have is probably the main factor. Would be interesting to see! Here are some pics of the Mi that might help:
Front: http://www.mdracing.co.uk/images/enginerem...large/pic53.jpg
Back: http://www.mdracing.co.uk/images/mi_install/large/pic47.jpg
End: http://www.mdracing.co.uk/images/mi_install/large/pic48.jpg
