madspikes 41 1 Cars Posted April 26, 2006 Does anyone know the pin outs for the crank sensor located on the gearbox of the 205, it has 3 wires? Im assuming ground, +12 and signal out? But in what order? I have a cunning plan to use this sensor (but in a new location) with a pully trigger wheel, but first I need to know how to wire it! Is this going to work? mad Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted April 26, 2006 It might be worth trying to figure out the wiring diagrams for a TD 205 with a rev counter as these use the same sensor for the crank position. I think its an optical sensor but I could be wrong. Graham. Share this post Link to post Share on other sites
madspikes 41 1 Cars Posted April 26, 2006 Humm... Thats food for thought. I hadnt thought about it being optical... Would explain the 3 wires. Share this post Link to post Share on other sites
Mad Professor 7 Posted April 27, 2006 I don't know about the pug ones, but most the ones I have been playing about with for my MS are 2 or 3 Pin. The 3 pin ones are just +/- & Sheild, Just connect up a volt meter to it and move the sensor over and past some metal. Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted April 27, 2006 I don't know about the pug ones, but most the ones I have been playing about with for my MS are 2 or 3 Pin.The 3 pin ones are just +/- & Sheild, Just connect up a volt meter to it and move the sensor over and past some metal. I don't think madspikes is talking about the ones used in the motronic or similar system but the standard un-used one with the plug on the rocker cover. Graham. Share this post Link to post Share on other sites
