Rally Slag 0 Posted April 15, 2006 Does anyone know if you can buy a new instrument cluster fro peugeot? mine dont work properly, so i got another set of ebay, they casing was slightly damaged and that was even worse than the original set. or if somebody has a set that they can garantee me deffanatly work from a phase 2 1.9 J plate car i'd happily pay for them, but they must not be damaged in any way and everything work properly. cheers guys Share this post Link to post Share on other sites
Jonmurgie 2 Posted April 15, 2006 You won't be able to get a new set... or if you can it would no doubt cost more than the cars worth!! Best just keep looking for a good set, several cars are usually being broken on here most the time... Share this post Link to post Share on other sites
Daxed 7 Posted April 15, 2006 I have one from a phase 2 that i will be removing shortly, everything works but it has about a million miles on the clock. Share this post Link to post Share on other sites
nick 3 Posted April 15, 2006 What bit doesn't work properly? Nick Share this post Link to post Share on other sites
Rally Slag 0 Posted April 20, 2006 the oil pressure gauge doesnt work, but the light does, the car must have oil pressure or there would be a big problem. the water temp gauge doesnt work but the light does, so i dont no how hot its getting. the oil gauge works but the light doesnt work, the fuel gauge works but the light doesnt work. Any ideas? the casing is also damaged aswell Share this post Link to post Share on other sites
Robsbc 0 1 Cars Posted April 20, 2006 chrisaxgt said: the oil pressure gauge doesnt work, but the light does, the car must have oil pressure or there would be a big problem. the water temp gauge doesnt work but the light does, so i dont no how hot its getting. the oil gauge works but the light doesnt work, the fuel gauge works but the light doesnt work. Any ideas? the casing is also damaged aswell Sure it's not the oil pressure sensor on the block that's kapput? You can remove the oil pressure/fuel temp gugaes out by taking the front perspex off and undoing the bolts at the rear. Share this post Link to post Share on other sites
mak 0 Posted April 20, 2006 cant you test the guage by earthing the sensor wires Share this post Link to post Share on other sites
Rally Slag 0 Posted April 21, 2006 i'll give it a try next time i go home and see the car Share this post Link to post Share on other sites
