miamistu 1 Posted April 12, 2006 Keep seeing that people use 90mm long trumpets with Jenvey throttle bodies which presumable give the same tuned length overall as the original manifold (including the little manifold, bodies and trumpets themselves) Does anyone happen to know how long the whole system is supposed to be from the head to the inlet of the trumpet though? Cheers! Stu Share this post Link to post Share on other sites
Mandic 0 Posted April 12, 2006 Yeah, interested in this myslef... Cheers Ziga Share this post Link to post Share on other sites
Jonmurgie 2 Posted April 12, 2006 I can measure mine in the morning but at the moment I can tell you that the Jenvey Bodies are 118mm deep (long or whatever) so with 90mm trumpets that's 208mm, just need the depth of the inlet manifold... Having spoken to Richard Jenvey himself about the inlet tract length he led me to belive that Peugeot along with Longmans had experimented with several different options and found that unless your building a 300bhp N/A Touring Car engine there's little need to deviate from the 90mm trumpets which give the best alround tract length for the Mi Share this post Link to post Share on other sites
miamistu 1 Posted April 12, 2006 That would be great, cheers Jon Share this post Link to post Share on other sites
James_R 3 Posted April 12, 2006 For the calculations on inlet tract length it's from the base of the valve, so if anyone has that measurement that woudl be handy too Share this post Link to post Share on other sites
Jonmurgie 2 Posted April 12, 2006 Although that's a measurement that people don't/can't change so not as important... everthing from the OUTSIDE of the head can be changed and with the more common Bike Carb's route with home-made inlet manifolds I guess it's important to know what kind of inlet tract your aiming for! Share this post Link to post Share on other sites
petert 615 Posted April 13, 2006 I think it's in the range 290-330mm, valve seat to trumpet. There's a few calculators on the net. Do a search. Share this post Link to post Share on other sites
petert 615 Posted April 13, 2006 (edited) Read this, http://mgcgti.clarkeandclarke.co.uk/Page28.html and this, http://www.civ.ed.ac.uk/~jchick/Y5/thesis/...ic_html/pt7.htm and this, http://www.rbracing-rsr.com/runnertorquecalc.html I got different results for the 285 deg. example on the MG site. It's interesting that whilst the formulas for the first two sites are the same, the method of calculating the ECD differs considerably, giving vastly different results. Edited April 13, 2006 by petert Share this post Link to post Share on other sites
B1ack_Mi16 67 Posted April 13, 2006 Length of port in head: 80mm Length of Jenveys (red ones), small manifold and 90mm trumpet: 280mm I'm not 100% sure of the standard inlet manifold, but I believe it's close to 280mm that one too. Share this post Link to post Share on other sites
Jonmurgie 2 Posted April 13, 2006 Cool, so that gives us the figures as follows: Head Ports: 80mm Inlet Manifold: 72mm Jenveys: 118mm 90mm Trumpets: 90mm Total: 360mm - though as the 80mm head ports don't get changed it's the 280mm figure that would ideally nee to be matched in any other setup Share this post Link to post Share on other sites
miamistu 1 Posted April 13, 2006 You sir, are a star. Thankyou very much Share this post Link to post Share on other sites
petert 615 Posted April 13, 2006 Mine differs a little: manifold - 100 TB's - 88 trumpets - 75 so a total of 343mm (inc. inlet port) Share this post Link to post Share on other sites
petert 615 Posted April 13, 2006 (edited) Here's another one, exhaust and inlet: http://www.btinternet.com/~mezporting/exhaust_length.html and another one: http://www.bgsoflex.com/intakeln.html Edited April 13, 2006 by petert Share this post Link to post Share on other sites
Bonzai 2 Posted April 13, 2006 (edited) my setup currently stands at Inlet Manifold: 180mm Jenveys: 118mm Trumpets: 45mm although this is all only sitting on a shelf looking sexy for now Edited April 13, 2006 by Bonzai Share this post Link to post Share on other sites
miamistu 1 Posted April 13, 2006 Bonzai said: my setup currently stands at Inlet Manifold: 180mm Jenveys: 118mm 90mm Trumpets: 45mm although this is all only sitting on a shelf looking sexy for now are the trumpets 90mm? Share this post Link to post Share on other sites
Bonzai 2 Posted April 13, 2006 oops no, i just copied and pasted jon's format edited now... Share this post Link to post Share on other sites
Galv 0 Posted April 20, 2006 Measured mine, I've got longman manifolds and weber 45's with 45mm trumpets and the distance from the head is 245mm overall. I'm not sure there is enough room for 90mm trumpets without some major mods to the slam panel Share this post Link to post Share on other sites
JR20516V 6 Posted April 21, 2006 Peugeot has probably spent a motza on getting the inlet manifold to the correct length etc which leads me to my question....would it not be best to attach TB's to the existing factory manifold. Has anybody done this and has pics, info etc. Very interested on your comments! Also is the Longman manifold an improvement on the stock factory jobbie?? If so ....why??? Share this post Link to post Share on other sites
Rippthrough 98 Posted April 21, 2006 JR20516V said: Peugeot has probably spent a motza on getting the inlet manifold to the correct length etc which leads me to my question....would it not be best to attach TB's to the existing factory manifold. Has anybody done this and has pics, info etc. Very interested on your comments! Also is the Longman manifold an improvement on the stock factory jobbie?? If so ....why??? The bodies would increase the tract length though. Share this post Link to post Share on other sites
Rik 0 Posted May 22, 2006 How come this thread has gone quiet? I'd of thought this would be a hot topic with the amount of people running bodies. I'm not looking for a necessary standard length, but a length and some assumptions/definates of the effect on torque of the induction length So far i've seen the following assumptions. For torque lower down in the rev range: -Injectors should be close to the head... -The inlet tract should be as long as possible... Now the standard manifold does all the above if modified for TB's, so i'm thinking of using the standard manifold and using the calculations posted, try and create a length of around 280 - 300mm, without the use of trumpets. as the standard induction headers are fairly long. i'll be using samcos etc.. to fit them to the manifold so i presume the length can be adjusted fairly easily to achieve the best torque curve. Any got any views on this Rik Share this post Link to post Share on other sites
Sandy 191 Posted May 22, 2006 The relationship between cam timing, inlet tract diameter, taper and length, all conspire to make the "ideal" length incalculable without pointlessly extensive modelling. Then you alter the inlet cam phasing and it all changes! The best bet is to make some provision in your set up for experimentation and commit some dyno or roller time to playing a bit, you'll be looking at a compromise of some sort either way. That said, in my meagre experience, maximising inlet length tends to bring more useful gains than settling for the easiest layout. And for gods sake drop the radiator and fit a heatshelild to ensure the hot air of the rad isn't your inlet supply, or your worrying about the wrong thing completely!! Share this post Link to post Share on other sites
petert 615 Posted May 23, 2006 sandy309 said: The relationship between cam timing, inlet tract diameter, taper and length, all conspire to make the "ideal" length incalculable without pointlessly extensive modelling. and rod/stroke ratio Share this post Link to post Share on other sites
Sandy 191 Posted May 23, 2006 Haha, true, that kinda comes under cam timing? Share this post Link to post Share on other sites
