Mad Professor
Advance Curve Data
Mad Professor
Hi All.
I am trying to find Advance Curve Data for the Standard 1.9 and or Turbo Technics 1.9 uprated vac unit, on the dizzy.
Before anyone shoots me down in flames I am using the (Search) button, and it seems a few peps have been looking for the data, but as of yet i have not found a post with what I need.
Can anyone help me with this?
Edited by Mad Professor
fiji bob
i did have a crypton tuning book somewhere for a standard 1.9 but i dont think it goes into too much detail regarding timing values, maybe you could trythis bloke im sure he is or used to be a turbo technics dealer.
Mad Professor
I did contact Alen Jeffy at enginetuner.co.uk
  Quote
Question: Do you have any data on the Mechanical Distributor Advance Curves for the 205 1.9 GTi and or 205 1.9 TT? Thanks...
Answer: Hi.. not as such, although they are pretty lousy! They all suffer with under advancing, which means if you set the ignition for best performance at over 3500 rpm, they pink like mad at 2000. We tend to use the Superchip Icon programmable piggy back with these, then setting the correct advance is a doddle. The Turbo Technics versions would probably be ok with the standard advance, as you don't want it to crank up so much anyway. TT supplied a retard capsule, which backs off about 8 degrees under load. Crude, but reasonably effective!
So that did not realy help me much, so I e-mail'ed Bosch, and got this in my reply from them.
fiji bob
found the book earlier, ill post the figures its got in it tommorrow.
