laser green 1.9
Bump Stops
laser green 1.9
I have managed to remove what was left of my two bump stops. Do the powerflex bump stops bolt straight to the body of the car. As you can see this is all that is left of the cups that hold the peugeot ones in place.
Ahl
Heheh, mine were even worse than those.
You still need the original peugeot 'cups' bolted in. The powerflex bump stops then go into those (with a bit of persuasion!)
mbayley77
Cant you leave them off entirely?
Ahl
Leaving them off is rather bad for the shock absorbers when the suspension really compresses.
You've also got issues with the wheels rubbing through the fuel filler pipe etc.
laser green 1.9
Do the cups from peugeot come with the rubber stops attatched. I'll have to ring them in the morning any how, but I just wondered.
They look different to the ones I've got fitted to my car's. :)
Don't think so, they are a seperate parts. They bolt through the middle of the cup & then you have to fit the bumpstop. (easier said than done).
You can also have difficulty at an MOT if the tester notices they aren't fitted afaik. :lol:
Graham.
Bats
I lost one of my bumpstops duringa a sprint event and noted that you can't get a power drill in to drill out the remnants due to the lack of space available, you have to drop the beam to get in. I had bought a rubber cone and steel cup, but as I didn't have time to drop the beam and didnt fancy the thought of the trailing arm contacting the fuel filler, decided to drill through the rubber cone and mount it on the flat section of the trailing arm with large tie wraps (not using the cup). So it is effectively acting upside down contacting the original mounting area. It seems to work and has not moved or fallen off during other sprint / hillclimb events. I don't know what the MOT tester will say, if anything. Can anyone comment further on whether this bodge is a problem for the MOT?
As long as it is there & securely held on it shouldn't cause a problem imo. You might only fail if the tester spots it isn't there.
Some people have used a high strength adhesive to stick the rubber to the body when the cup has rusted away iirc.
Graham.
Jonmurgie
Bumpstops fell off my car... never bothered putting them back amd have no problems, but I guess that's a track car so not as important?!
Craigb
The retaining bolt sheared on mine , so I puddle welded a new cup to the shell using the center hole for the puddle . As said earlier you can't get a drill in there .
Duroc
I just fitted my new ones last weekend. Had to wait 3 months for them!!!! Also the bolts they supplied weren't threaded far enough along, so I had to use my own. Quality!
Edited by Duroc
laser green 1.9
The parts guy at pug said that they would be in stock on thursday, called in today for the stops and guess what, no parts. If it get's past a week I'll have to go to auto five. I think they don't seem intrested in the old pugs anymore. :D They should remember what saved there company. ;)
Edited by laser green 1.9
