christopher
Help Me Calculate Compression Ratio
christopher
Can someone help me calculate the compression ratio of the engine I might build?
basically it is a 1587cc block and a TU24 head.
I get 8.6 which just can't be right...
Bore = 78.5 mm
Stroke = 82 mm
Head Gasket thickness = 1.5 mm
Deck Height = 2mm
Measured volume combustion chamber 32.4 cc
christopher
Cheers DrSeuss,
I've tried one of these but just can't get it right if I use the given combustion chamber volume?
Hence the question
DrSeuss
according to the figures you posted, i got around 9.67:1
tom_m
using that calculator and your measurements, i make the static CR 9:1
christopher
I just don't get it. I expect a TU5 combustion chamber (106 Rallye) to be bigger then a TU24 (1,3 Euro Rallye) so the CR should go UP if I put the TU24 head on a TU5 block
A 106 Rallye has a CR of 10.2
A 205 Rallye has a CR or 9.6
Now I'm still confused :P
Edited by christopher
crogthomas
Calculating it by hand I also get 9:1 using those measurements given, assuming that by deck height you mean the distance the piston is down the bore at TDC?
What other differences are there?
Are the pistons flat toped?
Rippthrough
Is that the compressed head gasket thickness?
christopher
  Quote
I dunno I suppose it would be a standard 106 Rallye cast iron gasket I would work from. I just measured the old one
christopher
I'm getting the same result about CR=9. This means that the combustion chamber on a TU24 Euro Rallye is actually BIGGER then a TU5 one :P Can this be???
B1ack_Mi16
It gets at 9:1 with your information, are the piston flat-tops? Do they have valve-cutouts?
Edited by B1ack_Mi16
trogboy
I'm getting 9.04:1
Like B1ack_Mi16 said, are you sure of the bottom end/piston data? i.e. deck height, flat topped, deck height, crowns, dished, cutouts etc.
Also what have you used to measure the thickness of the used head gasket?
