jr4070 0 Posted January 16, 2006 Does anybody else have the fan, (when selected on) making a vibrating noise under acceleration ?I think its days are numbered. On my phase one car the controling resistor went but this sounds like the bearings on the heater fan shaft itsself. Share this post Link to post Share on other sites
M3Evo 0 Posted January 16, 2006 Mine started making an awful shreiking noise once. Took it apart, stripped the motor down and re-greased the bearings. There are also a couple of felt washers in there which probably need replacing. If you squodge a load of grease into them it presumably keeps the little bearings lubricated Don't obey the Haynes manual when you take the motor out though, it tells you to dismantle the interior of the car, when you only need to stick your head into the passenger footwell and undo 3 screws and a plug! Share this post Link to post Share on other sites
mak 0 Posted January 17, 2006 jr4070 said: Does anybody else have the fan, (when selected on) making a vibrating noise under acceleration ? Does anyone else have the fan make no noise when its on is more the question! As M3Evo says regreasing the bearings should sort it. Where abouts in Swindon are you? What colour is your Gti? Share this post Link to post Share on other sites
jr4070 0 Posted January 17, 2006 mak said: Does anyone else have the fan make no noise when its on is more the question! As M3Evo says regreasing the bearings should sort it. Where abouts in Swindon are you? What colour is your Gti? /quote] Sorrentto, and out towards wooton Bassett..I'm the old git, with the big grin.. Share this post Link to post Share on other sites
mak 0 Posted January 17, 2006 All GTi drivers come complete with a big grin, so I'll just keep my eye out for the old git Share this post Link to post Share on other sites
