Livelee
307 Hdi Brakes
Livelee
Hi
I've just taken delivery of a 307 brake upgrade for my 309.
I asked for "The discs, calipers and yokes from a 307 HDi".
I was quoted £180 delivered. Turns out that was + VAT ;)
Anyway, they turned up this morning and I think i've been sent more than I asked for.
Below are the pics of what I've receiced. I've got a pair of each of them. Could you tell me what I need and what (if anything) I need to (try) and get a refund on.
http://www.livelee.plus.com/pugbrakes/100_2990.JPG
http://www.livelee.plus.com/pugbrakes/100_2991.JPG
http://www.livelee.plus.com/pugbrakes/100_2992.JPG
http://www.livelee.plus.com/pugbrakes/100_2993.JPG
http://www.livelee.plus.com/pugbrakes/100_2994.JPG
http://www.livelee.plus.com/pugbrakes/100_2995.JPG
http://www.livelee.plus.com/pugbrakes/100_2996.JPG
http://www.livelee.plus.com/pugbrakes/100_2997.JPG
http://www.livelee.plus.com/pugbrakes/100_2998.JPG
http://www.livelee.plus.com/pugbrakes/100_2999.JPG
http://www.livelee.plus.com/pugbrakes/100_3000.JPG
Many Thanks
Dan
Edited by cybernck
huckleberry
As far as I know you won't need pic 5,6,7 and 8, what is 9? Master Brake Cylinder? Don't believe that fits from a 307 either.
madmat
Looks like one of the calipers has melted,best take a look at that before fitting?Have you measured the diameter of the discs?The last pic looks like a close up of the discs!
Edited by madmat
Livelee
Melted!!!! Perhaps I should go and clean them up and take some more pics. Warm soapy water ok?
Yes the last pic is a close up of the disc.
What have I got in pics 5,6,7. I guess these are the "yokes"? If I don't need them then what are the yoke things that people talk about.
*Mechanically i'm a complete novice, I know nothing ;-)
sonofsam
Yokes i dont think they are..look more like hubs and hub carriers to me.Yokes are the bits that conect the caliper to the hub carrier,correct me if im wrong.there is a great guide on the main site
Edited by sonofsam
madmat
Sorry,didnt mean to alarm you! its just the caliper in the 3rd photo looks a little strange near the piston.
Livelee
And I guess I don't need tham? What's a yoke then?
sonofsam
Yes you need the yokes and not the hubs as in your picture.Yoke connects the caliper to the hub by way of two bolts and a metal strap type thing,personally i think you may have paid over the odds for what you got as brand new complete setup is £250 ish.
A good search will bring up loads of posts and info on this subject..and the main sight guide also ;)
Edited by sonofsam
Livelee
Well the fact that there is £82.25 worth of hubs that I don't need that should make the price a little more reasonable?
Have I got the yokes? can they be seen in the picture, I can take more if needed.
Many Thanks
Dan
madmat
Arent his yokes allready on the calipers?
sonofsam
Many Thanks
Dan
Wasnt try to diss you Dan and if get refunded on the hubs then i guess it makes it a bargain ;)
Livelee
Didn't think you were dissing me at all mate. :D
I've just been and scrubbed down the caliper and I think the yoke is on there. Just gonna try and undo the bolts.....but i'm expecting them to be hard.
No idea why life the discs have left but the pads look good.
dan
Livelee
What's a yoke then?
This part is the Yoke - basically the part that gets bolted onto the hub, and then the caliper bolts to (although when you remove what people usually call the "caliper" from the car, the yoke and caliper come off as one, and only seperate when you strip them down like you have)
But yes, in answer to your question, the parts you need all appear to be there and present ;)
madmat
Hi,looks like that melting is some plastic thats dripped on,if i were you i would make sure they fit first then give them a good wire brush and paint.Have you read the fitting guide on the main website?
Livelee
Hurrah. Many thanks mate.
Yes, i'll be painting them after a severe clean up.
crogthomas
Picture 2994 is what is properly known as a 'knuckle'. Often people refer to them as a 'hub' or a 'yoke', which is what you asked for. Therfore you got it.
Livelee
Knuckle, blimey more thingys to ask for.
Like I said above, I'm a complete novice so I just asked for the stuff listed in the guide on the main page.
Why would 2 parts in a brake system share the same name? surely this is going to lead to problems like mine?
Banjo
They look like they came off a burnt out 307 to me, I would take the seal off and the piston out to check for damage inside if I were you. Also are you seriously gona use the disks and pads?!?
Edit; your getting mixed up mate, you've bought 307 hubs, you need to send those back.
Ben
Edited by Banjo
Livelee
Ben
Is there something wrong with them then? ;)
Edit: the discs and pads I mean
Edited by Livelee
sonofsam
I,ll get my coat..and maybe some yokes too.now i know what they look like,cheers Anthony
Glad you got all the bits you needed Dan ;)
Sam.
tom_m
dude i don't wanna rain on your parade but they look like they've been in a fire! i hope your getting them rebuilt, or at least checking them out properly, if the seals have been cooked those will be dangerous!
bin the discs and pads and get new ones
Livelee
:lol::):D
I'll get somebody who knows stuff to look at them.
Livelee
Good news :(
Dad has checked them out and it's all good. We're going to get a seal kit and rebuild them but he says they are more than good enough. Pads fine, discs fine.
All I need to do now is convince the breakers to collect the hubs and give my money back. Then the lot will have cost me £150 delivered.
DrSeuss
Brand spanking new pads are only 20ish quid. Remember when dealing with brakes, one has to ask the question, how much is my life worth? For me at least, its worth the cost of new pads.
