smckeown
Plastic Welding
smckeown
Following on from PeterT's advice here.
Does anyone know of a firm that can plastic weld ? specifically cut fuel tank in half and weld it back up
cheers
sean
JERAM
cheers
sean
not advisable on a fuel tank, you would need to be off you head to do that :)
bren_1.3
if the tank was dry as a bone of fuel then why couldnt you??? sounds like a damn good idea from what petert was saying. well worth it IMO.
JERAM
yeh great idea!!!!
i wonder if it will still be a good idea when one splits and the flames are licking out your arse :)
my opinion only, would you want to risk it!!!
Hilgie
Another question is why do you want to cut and weld it?
The only reason I can imagine is if you installed 4WD, then it is absolutely needed to cut the midsection away a little.
bren_1.3
fuel weight saving for a track car. which can be quite a lot. its just cost effective instead of buying an ali tank mounted in the boot.
read the thread posted by smckeown, in particular petert's comments.
Sam
Does plastic absorb the petrol like aluminium does? When I asked a few places about welding my ally tank I had they all said that they couldn't because aluminium absorbs petrol to an extent, so it is dangerous to weld.
Nickoff
Would it be easier to find a smaller tank from a different car perhaps and somehow adapt it to fit the 205? (yes this probably is a stupid question :) )
C_W
Just put less petrol in! :):lol:
Powers
I am planning on designing a aly tank that is half the size of the original (Passenger side) and of a similar shape. Then relocating the filler to the passenger side. This should not only prevent fuel surge and starvation, as the tank will be foam baffled, but also move the C.of.G of the car.
The tank plastic melts at approx. 60 deg. C. It's quite safe once the tank is stripped and rinsed with water. It's done with precision equipment, a bit like TIG welding. Definitely not for amatures. Probably only relative for true competition cars. What's the point in carrying around 50L (38Kg) of fuel when you can get away with 15L (11Kg)?
TheUltimateWarrior
Can someone explain to me how the heck you weld with plastic!
Hilgie
I used a tank from a motorcycle in my autocross Vauxhall. Was running carbs anyway, so made no difference. Took about 20litres of fuel and it was sitting just behind the passengersseat on the floor.
Jonmurgie
if you've installed a fuelswirl pot then just run with less fuel in the main tank... 1/4 fill it only etc. :)
smckeown
This isn't a proven solution thought ? as the tank is still do wide and still has 2 sections, there's no proof that you can run low amounts of fuel in the main tank. Plus I like the idea of just having 1 smaller tank and none of the other gubbins, much simpler solution
ashlee205gti
Quite simple really, i used to work opposite a place that specialised in making cabins for catteries and other 'pet hotels'. Works similar to metal welding in the idea that it 'melts' two sections together and it's also surprisingly strong.
Paintguy
Me :lol:
Admittedly, I've never done a fuel tank, but I've done just about everything else :)
smckeown
Me :lol:
Would you be able to supply one with any appropriate pressure testing performed ?
Paintguy
Ahh... That'll be a no then.
Sorry, getting carried away with myself, and opening my mouth before thinking through the implications of such a job.
smckeown
the quest continues.... :)
Paintguy
Good luck with the search :)
After reading the other thread, it certainly sounds like a workable solution. Next time I'm up the scrappies, I'll blag myself a tank, and give it a go. (not that I'll ever need such a thing myself)
taylorspug
Sean, its funny you should bring this up, i formulated exactly the same plan for the tank on my Golf yesterday. I *think* i know someone in Lewes who can do it if you're interested? :lol:
smckeown
am I ever.......let me know if he's up to the job etc.
