Gavin Waddell
Under Dash brown multiplug confusion
Gavin Waddell
I am making a loom for my engine managment and i have a question about the under dash multiplugs.
I have gone through the wires with a multi meter checking that they are in the right place, and all is good apart from 2 wires:
Big plug
pin 9 should be starter but is a positive switched live i think.
Small plug
Pin 6 seems to go to starter and should be a positive live.
me thinks
I have attached a photo.
Any ideas.
Gavin
Gavin Waddell
So i wentand checked on my car and the feamle plug is wires the same so should be all good.
There are two configurations of wiring that swapped 2 wires at some point. I can't remember the details now as its been a while, but it sounds very much like what you have found, an ignition live and a starter live swapped round. Its just a case of swapping the two wires around if needed.
typically it is just those two wires that are swapped around, easy enough to rectify.
