DamirGTI
XU10 oil pump bolts torque ?
DamirGTI
As above , anyone remember how much Nm's where the 6 bolts which join the two oil pump halves ?
15Nm or 20Nm ? not sure !
are they m6 or m7?    m6 probably needs 13nm, m7 20nm.
DamirGTI
M6 !
It felt like about 15Nm whilst undoing ..
Cannot remember where was that torque spec in which book/manual ?! :wacko:
I don't recall it being shown, they don't want you to open them up  :lol:
DamirGTI
Hmm , fair point !
I certainly did open them before , no idea about how much Nm i've been using to nip up those bolts , the joys of getting older :ph34r:
Way too many PSA crap all around the place , parts and books/pdf's too , think i've had/seen some paper about oil pumps ..
Anyhow speaking about crap , i went digging and found two more XU10 pumps , and some peculiar hoses with posh bends and mint looking turbo actuator all which i long forgot about having , will do handy for this engine build !
I tried my small torque wrench on the bolts of those spare oil pums and it clicks at about 11-12Nm , at 14-15Nm it starts to tighten so 15Nm is too much ..
So it's either 10 or 12Nm id say .
SRDT
They don't really mind if you undo the bolts because they sell you some of the internal parts and also have small baffles that uses those bolts. Now it's true that the torque spec feels a bit like a trade secret.
I managed to find a value on the very first Citroën XUD worshop manual and it's 0,9 m.daN so yes it's close to 10 Nm.
Edited by SRDT
  • Thanks 1
11Nm for me and a dab of 243 Loctite. If one of those suckers comes undone it’s curtains. Ditto for the piston oil sprayers.
  • Thanks 1
DamirGTI
Brilliant !
Thanks to both of you ! B)
DamirGTI
Oh , one more thing ..
How about mixing/swapping the halves from one pump to another , and same for the gears , possible or best to avoid ?
SRDT
Halves feels fine as long as it's the same kind but I'm not so thrilled about the gear. Neither is Peugeot because you can't buy the gear but you can order some of the pickup halves.
DamirGTI
I see ..
From the lot of the pumps i have various conditions of the individual parts , but all still pretty good considering the age .
Interestingly one pump which has pitted gears has the best pick up halve with almost zero scoring .. so been thinking of using just that pick up halve on one of the other pumps with good gears .
They're all XU10J2TE pumps ...
I have swapped the halves but not the gears themselves.
SRDT
Peugeot did sell the idle gear alone for some older engines with the gear housing machined inside the engine block but I wonder how often you find that only that one gear is toast and the rest can go on.
DamirGTI
Indeed , most of the pumps i've taken apart where good with just minor scuffs made by the gears rotation against the pick up halves ..
On the one with pitted gears , i found a lot of crap underneath the pick up mesh .. strips of silicone sealant , metal shavings and some plastic like specks .. so id say well worth having a look at the pick up mesh at least , if not opening the entire pump body !
I always completely strip the pump. Anneal the tabs on the screen cover after removing it, otherwise they'll crack off on the way back. It's impossible to clean out the screen properly otherwise.
Edited by petert
DamirGTI
Yes , the tin screen covering the mesh is a bit dicky to secure back tightly to the pickup ..
I haven't been heating the tabs , and i only bent them slighty open so i can slip the sreen off , bending them back so they hook on the pickup took some time till it was tight enough .
DamirGTI
Some more !
Not the oil pump , but the oil jet gallery plugs on the sides od the block .
Had to open them up cause there was some metal shavings inside from the machining the block .
How much Nm for those and what do we put on the threads ?
Thread lock , anaerobic sealant , shellac , non setting synthetic sealant etc ..
Seems like there was some sealing paste from the factory, something yellow/withe does not look like thread lock
