Bremar
Clicking and intermittent starter motor turning
Bremar
Just a quick question maybe. The car always starts but the irregular click but no starter turning remains.
Surely the Click is from the solenoid trying to engage the starter motor and so the problem is never with the Brown connector or indeed with the connection of the black wire to the starter solenoid (unless the car just won’t start). Not really thinking
I originally launched into finding and cleaning the brown plug, but the issue persists. Surely the single click  is actually the starter solenoid kicking in so the problem must be elsewhere - say the connections inside the solenoid or the starter motor main connections or  the starter motor? Or am I misdirecting myself?
thank you Bremar
Edited by Bremar
PhilNW
The red wire from the ignition switch to the starter solenoid has been a common reported problem.
Try running a jumper wire from the small solenoid terminal to the battery to check it turning over every time you touch it to the battery terminal
it absolutely can be the brown connetor, or red wire on the ignition switch, every joint or wire that has more resistance than intended will lead to a voltage drop, a voltage drop will prevent the solenoid from travelling its full sweep and making contact completing the circuit and firing up the starter motor.
dont forget the solenoid also does the task of throwing out the gear into mesh with the flywheel.
