mmt
Rod bearings
mmt
Hi guys
I need your help to find oversize bearings for Gti6 xu10j4rs engine.
I need 0.5 oversize Can anyone help with a producer and product number.
anything :-)
thanks.
Peugeot do them, or used to as I remember buying them in error many years ago :ph34r:
most bearing manufacturers will have something to suit, King, Glyco, Victor reinz, mahle etc
SRDT
The only oversize set is 0606.Q2 but I'm not sure if it's +0.5 or something else. Standard size is 0606.X0 bdw.
Those are for the XU10J4RS only, Peugeot has (had?) other part numbers for XU10J4R rod bearings : 0606.N6 / 0606.S4 for engines with drilled rods and 0606.L4 / 0606.N9 for the handfull of early engines with non drilled XU10J4RS rods.
5 hours ago, petert said:
I'd find another crank, as XU10 cranks are dime a dozen
XUD or DW10 might be, last Xu10 was made in 2002, the 135 bhp engines have long gone in the bin up here as nobody wanted them.
mmt
Out of Stock is all I get whereever I ask
do you know if anyone would shop to Denmark ?
DamirGTI
+0.30 oversize seems to be max , and those are available from Glyco .
Try "King Bearings" catalogue , they usually have quite a lot of odd sized bearings .. and few race variants too .
